20 Most Recent
Ignition System for Honda Prelude Questions & Answers
What part do I replace on my car
Hello Connie,
Do you have a lot of keys on your key ring for the car?
It might be too heavy and that could have weakened the Ignition Switch.
If so, Remove some keys and just use the Ignition key.
If you still have to hold it in the ON position, then I think you need a new Ignition Switch.
Good Luck!
Andrew
Lightbulb replace hondaaccordradio1998
I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 yearsmust try this bitman and reliable-store. Both are good
Gx610 Honda v-twin small engine one side want fire
Hi, If you did the usual testing (comp,Carb cleaning, etc.) then I would go to the electronic ignition box if it has one. I've been fooled before. Checking for spark, wire off, or plug out, isn't the same as a plug under compression , Good luck.
