20 Most Recent RCA RT2390 System Questions & Answers
Hmm. let me see if I get U correctly. you use u'r theater system with a TV and the audio is fed via optical or U have DVD player that you can feed the audio via optical or coax. I think it is the later, if it is U could be having trouble with sound decoding setting of the DVD player itself. It's like mpeg out or PCM out instead of full DTS or 5.1 dolby digital decoding. If this is the case just use u'r dvd remote and check the audio play back settings. If this does not solve u'r problem, pls state u'r set up briefly, so tht I can understand the type of connection u use. Happy troubleshooting Rifaa
RCA RT2390... | Answered on Oct 27, 2018
The subwoofer jack might be switched off. Have a look under the menu of the system to see if it is off.
RCA RT2390... | Answered on May 01, 2016
Codes are stored in the remote. If your Brighthouse remote is programmable, you can search for a suitable code. If a complete search of all codes stored in the remote is unsuccessful, you may have to try another remote.
RCA RT2390... | Answered on Sep 06, 2014
Most universal remotes have many codes for many manufacturer's products stored in them. They may not have the exact code for your device, but they probably have codes that will work most of the functions of your device. If you'd like one that has direct mapping to keys, you'll need a learning remote. These remotes allow you to point your remote's IR emitter at the learning remote's IR emitter/receiver and map any or all of the buttons to the buttons you choose. On mine, I created a spreadsheet ahead of time that shows what buttons are mapped to which commands.
RCA RT2390... | Answered on May 09, 2014
Clean dust from fan
RCA RT2390... | Answered on May 19, 2012
Hmmm, lack of ventilation, shorted speakers or wire, excessive volume?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/RCA-RT2390-Home-Theater-Systems-manual/id/402ag604/t/2/
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
RCA RT2390... | Answered on May 28, 2011
No,unless you somehow modify the power supply by putting a 220vac to 115vac transformer.If you just used it without the mod, it would probably catch on fire or something like that.
RCA RT2390... | Answered on Feb 14, 2011
RCA RT2390 System Logo
45 questions posted
Top RCA Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Audio Players & Recorders
Most Popular Question
surround help
  • Audio Players & Recorders
