20 Most Recent RCA T13208 13 in. TV/VCR Combo Questions & Answers
Do I need remote to play tape/use DVD player?
use the buttons on the tv.
7/18/2010 11:05:50 PM • RCA T13208 13... • Answered on Jul 18, 2010
Tv/vcr turns OFF after a few seconds when turned ON
check all your cables installed in your vcr and tv it might be grounded.
8/9/2009 9:48:36 PM • RCA T13208 13... • Answered on Aug 09, 2009
External DVD won't play - no manual available anywhere
The tv has a set of imputs for audio and video ,there is a posibility your dvd is not working right,you can also try a vcr by using the rca audio and video outputs of the vcr to the rca audio and video imputs of the tv,that will tell you if the dvd is not working ,the tv should have a switch selector for video and antena or have a channel below 1 called aux.
2/17/2009 1:45:30 AM • RCA T13208 13... • Answered on Feb 17, 2009
Is there a video button?
There should be an input button on either your remote or TV.
I hope this solution is helpful. Please take a moment to rate this solution.
2/11/2009 9:22:40 AM • RCA T13208 13... • Answered on Feb 11, 2009
Rca tv/vcr combo model T13208
Recording speed is the last item on the timer programming. SP or SLP. Some remotes have a button that will allow you to change the speed, when recording manually.
9/18/2008 4:00:25 AM • RCA T13208 13... • Answered on Sep 18, 2008
LEFT BUTTON ASSEMBLY
i had the same problem i ordered it from this site $10
https://www.vancebaldwin.com/webwiz/wwiz.asp
5/24/2008 7:50:18 PM • RCA T13208 13... • Answered on May 24, 2008
3answers
RCA T19064 - HOW TO GET TO MENU
i have the same set i used a rca universal remote rcr311w i think its the oem one i bought two of them at walmart i don,t know if they still carry them
2/7/2008 2:24:17 AM • RCA T13208 13... • Answered on Feb 07, 2008
TV/VCR combo
Try clean the AC head with a
foam type head cleaning Q-tip
when you take the cover off
tle AC head is the device
to the R of the drum that
resembles a recordling head
because thats what it is
clean the dark strip up
uner the littl ridge at the
top
11/22/2007 2:07:11 AM • RCA T13208 13... • Answered on Nov 22, 2007
RCA T13060GY
You or someone may have press record and the set is in record mode. that way whatever time it's set for it will come on. Or you have to unplug to reset. Leave off for atleast 1hour then plug back in.
9/26/2007 4:14:24 PM • RCA T13208 13... • Answered on Sep 26, 2007
Changing the Recording speed from SP to EP on TV/VCR Combo using universal remote?
I am sorry to have to tell you this, but the only way to change the recording speed is with an original remote. If you look on the original replacement remote link I posted here you will see the SP/EP selector, this is to change the recording speed. Good Luck. http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=DS13TVR90&brand_pn=FISHER_DS13TVR90&mode=large&uid=11755283300930
4/2/2007 5:40:22 PM • RCA T13208 13... • Answered on Apr 02, 2007
TV On/Off button blinks but never turns on.
Ok you did not cause the problem as you could always turn on the TV set from the front panel button,, If the TV set will not turn on even with the front panel button, there is a major fault with the TV set. This is not a reset that can be done by the user as there is a circuit fault and will require you to take the TV set into a shop to be diagnoised or replaced. Good Luck
3/27/2007 4:13:24 AM • RCA T13208 13... • Answered on Mar 27, 2007
In RCA T13208 13 in. TV/VCR Combo shut down after turn it on
The safety circuit is sensing a problem and is why it will not let the tv stay on,the cause could be a problem on the mechanics of the vcr,you need to get an estimate to see if it is worth the repair and might be able to keep using just the tv.
9/24/2006 9:31:14 PM • RCA T13208 13... • Answered on Sep 24, 2006
2answers
Vcr non-function
Theres no reset as I know but I only had a couple of these types of RCA and both had tv problems.. In todays VCR's there are no belts to replace or go bad. Mostly all nylon gears and plasic chassis. Most of the faults that lie with todays VCR's are bad Capstan motors ,defective tape loading carriages, defective mode switchs or sometimes even bad cylinder motors. If any of the gears break or cracks it will completely throw the unis mechaism out of alighnment and you will need to know from the manual where to set every gear ,lever and switch or it will never work.. Thats why most VCR;'s today are throwaway as you have to buy a service manual spoend time finding out why the mechanism dosent work and then buy the parts to correct the fualt. Good Luck to ya and heres a # you can call if you do decide to take the unit in for service by an RCA guy.. https://www.rca.com/secure/service/contactrca/1,,,00.html
4/20/2006 7:31:09 PM • RCA T13208 13... • Answered on Apr 20, 2006
2answers
Powers up but shuts down when play button is pressed RCA YLG43E
Try to check the power supply output side where anything could came into contact with positive and negative line for which when you press play button then it shuts down.
3/25/2024 6:44:15 PM • RCA Televison &... • Answered on Mar 25, 2024
Black and white screen only on DSTV?
RCA video cables handle analog signals. HDMI cables carry digital video signals. You need a converter. If you are using a component video converter, check if you swapped two of the three RCA video cables. (There are some A/V projectors that can do the translation of RCA and HDMI internally. Most TVs do not.) I hope this helps. Cindy Wells (One of my family's TVs used a dongle to condense the analog video signal to a single port, swapping blue and green gave a black and white output, IIRC.)
3/24/2024 11:03:58 PM • RCA Televison &... • Answered on Mar 24, 2024
I have an RCA re20qp80 remote that the mute button doesn't work
Most modern tv remotes are not normally designed to be repaired. You will possibly need to replace it. there are plenty of cheaper after market version that will do the job just as well. Your other option, and yes I know this is a silly answer, when you want to mute the TV is to simply press the volume down button to zero then turn it back up when you want sound.
2/23/2024 10:21:26 AM • RCA Televison &... • Answered on Feb 23, 2024
2answers
How to connect rca vr667hf to tv
you will need to rind RCA to whatever input is on your tv google RCA to HDMI copy and paste link for manual https://www.manualslib.com/manual/313476/Rca-Vr677hf.html#manual
2/18/2024 4:51:27 PM • RCA Televison &... • Answered on Feb 18, 2024
RCA T13208 13 in. TV/VCR Combo Logo
16 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
rca t19064 get menu
  • Televison & Video
