20 Most Recent
RCA F27450 27" TV Questions & Answers
Tv won't stay on
My tv is a Toshiba. It comes on for a second and then goes off by itself. I use the remote and the power button on tv and the same thing happens. Is there a solution to this?
RCA F27450 27"...
Answered
on Apr 25, 2016
CODE F13 ON HOTPOINT AQUARIUS WASHER/DRYER
Do u want to resolve the f-13 fault code on HOTPOINT Washer Dryer units
Fix the fault . It is a tricky job but the heater thermostat switch has tripped as it senses something burning. Probably a little bit of fluff on the heater element inside the heater unit.. There are 2 switches on top of this heater unit. One where the 2 blue wires go on the top left of the 3rd picture and the other which has a tall black wire connector on shown in the middle of the 3rd picture. Remove that connector and undo the holding screw . You can then reset the switch. The switch is a small circular switch hidden beneather the connector on the photos. This thermostat switch has a yellow. red dot ontop of it. If you use a small pin or needle and press into that dot you will hear it tick back into place. you have reset the switch now. You will probably need to clean the inside of the heater element unit to get rid of the fluff particles or it will keep switching off. To take this apart you will need a set of Star screwdrivers. Its a bit tricky but you will be able to undo the star screws and take them all out. I will add some photos to show you the unit apart. You can see the build up of fluff on the photos i have added from my hotpoint WD860 heater unit. This is a tricky job and takes about an hour due to the screw being awkward to take off and put on again but mine hasnt faulted for 2 years since sorting it out. You can buy a new Thermostat switch which is about 10 - 20 pounds sterling from Hotpoint or other spares stores.
RCA F27450 27"...
Answered
on Nov 15, 2014
My toshiba tv wont turn on
FIRST GREEN LIGHT WOULD COME ON. TOOK IT AWHILE BUT ITWOULD FINALLY TURN ON...NO NOTHING. IT'S GETTING SPARK CAUSE WHEN I PLUG AND UNPLUG IT AT THE SOURCE OF ENERGY IT SPARKS. FUSE IS NOT BLOWN
RCA F27450 27"...
Answered
on Jan 08, 2013
I have 2 black spaces on each side of my screen
The width of the picture is less than normal. It can be adjusted by entering in to its service menu options. But, entering service menu options and adjusting data values there is a skilled task. It will be best to contact any expereinced service techinician ot do this. Or Visit the site named 'Electro-help' for more details. Check this
link and select the site. View it in
'Flip card' option, which can be selected from the drop down box menu at
the left top corner or the display window. It will make search easy. If you are confident that you can do this, just proceed. If not, do not tamper the TV.
RCA F27450 27"...
Answered
on Aug 06, 2012
We have a Sony rear
The problem on your tv is the leaky electroltytic capacitor on the regulator section.
Replaced the capacitor on that area and your unit will be back to normal again.
If you don't have an experience in electronics find a qualified technician to do the job for you.
Have a nice day!
Thanks for using fixya.
JDVillanueva
RCA F27450 27"...
Answered
on Feb 06, 2011
