20 Most Recent RCA F36650 36" TV Questions & Answers
2answers
I need a transformer
Hello
It is not clear from your post, that which transformer part number you wants to know. Anyway I'm hereby send you the part numbers of it two main transformers.
[1] Horizontal Ouput Transformer, or Line Output Transformer or Flyback transformer [HOT or LOT or FBT]; Part number is (257807)
[2] Switeched Mode Power Supply transofrmer [ SMPS transformer]: Part number is (257807)
OK.
6/14/2016 1:46:27 AM • RCA F36650 36"... • Answered on Jun 14, 2016
2answers
Rear screen tv
replaced flyback transformer
4/29/2016 8:54:27 AM • RCA F36650 36"... • Answered on Apr 29, 2016
3answers
Owner Manual
plug it into the "input 1" on the back and select chanel "91" on the remote...you'll get "video 1", 92 for video 2 and so on.
10/14/2014 1:54:16 AM • RCA F36650 36"... • Answered on Oct 14, 2014
2001 rca tv F36648 why does the volume go up on its own i cant get it to come back down
The fault is with its electronic volume control voltage regulation. Might be due to a leaky transistor. The 'Mute' control section circuit should be checked. Actually this is not a user repairable fault. These circuit sections are at the main board's system control section circuits. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
4/25/2014 1:03:04 PM • RCA F36650 36"... • Answered on Apr 25, 2014
Power light blinks three times then nothing
A green LED that blinks On and Off is an indication on some models that the TV is receiving commands from a remote. By modelling, it just check SYN, SYN-ACK signal between transmitter and receiver. No worries.
11/24/2013 4:27:44 AM • RCA F36650 36"... • Answered on Nov 24, 2013
TV will not power up. Makes a buzzing sound when plugged back in
Replace the Flyback Transformer.
10/5/2013 3:09:58 PM • RCA F36650 36"... • Answered on Oct 05, 2013
manual
Audio goes and remote no longer works after 15
Check its main system control IC section circuit voltages. Download the repair manual to this set, and refer it for details.
8/12/2013 2:26:23 PM • RCA F36650 36"... • Answered on Aug 12, 2013
0answers
2answers
GREEN VERTICAL LINES
vertical line ic no pda 3653
4/16/2013 11:06:29 AM • RCA F36650 36"... • Answered on Apr 16, 2013
When plugged in a chirppy high pitch whin sound comes from back of set
It sounds that the Flyback transformer has damaged. Contact any experienced service technician if you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center
2/7/2013 2:16:47 PM • RCA F36650 36"... • Answered on Feb 07, 2013
Menu keeps popping up
If you have the guide plus feature go into the setup for it and when it asks if you have a cable box, indicate no, when it asks if you have a Vcr also indicate no. Last if it asks for the zip code enter all 9, This should rule the Guide feature out of service and you will know if it is your problem or not---it created a lot of problems in sets that had it, especially RCA or GE sets.
12/21/2012 1:41:04 AM • RCA F36650 36"... • Answered on Dec 21, 2012
Do they sell a wheel kit for bottom of tv, so I can roll it around on a hard servove rather than picking it up
Contact the nearest authorized service center for RCA for more details. In most cased, they will have it.
8/23/2012 9:58:59 AM • RCA F36650 36"... • Answered on Aug 23, 2012
How to zoom in and out
You must have its original remote control to access this function.
8/1/2012 2:06:22 PM • RCA F36650 36"... • Answered on Aug 01, 2012
The tv wont light up
1) test the power supply , see the blown fuse or c.breaker tripped and reset.2) Proof again, if the problem persist the problem arise with the power supply, some diode, capacitor, resistor, etc can be open or short. repair.test the power cord too, and main switch for open 3( see the diagram .God bless you7_13_2012_10_37_36_am.png7_13_2012_10_37_59_am.gif
7/13/2012 10:38:09 AM • RCA F36650 36"... • Answered on Jul 13, 2012
Power light flashes, tv will not come on
If the power light flashes, it is an indication of shorted component/s on the main board circuit. most probably it will be with its Horizontal Output section. Horizontal output transformer, Horizontal Output transistor etc: Your set need a detailed check up.
6/21/2012 11:27:20 AM • RCA F36650 36"... • Answered on Jun 21, 2012
When i turn it on it makes a screeching noise
Hello
This type of noise usually comes from a CRT based tv will be from its EHT cap. EHT cap is one which connected to the top of the p[icture tube, through which the extra high tesion voltage is supplied to it from the line output transformer. Normally there will be a smell of Ozone gas from the back side of the TV. Eht cap is a silicon rubber boot that protects the inner high tension voltage from being come to contact with open air. Due some reasons, if this rubber cap has some trouble; the extra high tension DC voltage supplied to the CRT [it usually come up to 32KVDC [32,000 VDC] will happen in contact with the open air, and if the humidity in air also is great, arcing will take place, converting Oxygen in the air to get converted to Ozone. If you look through the ventilation holes of the TV, in absolute darkness, you can see a bluish glow there aroung this anode cap. In some cases, this rubber cap can be replaced with a new one if available. if it is not available, you have to replace the line output transformer; otherwise called as [LOT]. This anode spot is a dagerous one for an unexperienced person to handle. because charged voltage will be there for a long time after switch OFF the TV.
It is best to contact an expereinced service person to get it repaired. OK.
7/4/2011 4:19:16 PM • RCA F36650 36"... • Answered on Jul 04, 2011
RCA F36650 36" TV Logo
181 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
green vertical lines
  • Televison & Video
