20 Most Recent RCA 36V550T 36" TV Questions & Answers
0answers
0answers
Tube is about to blow out of rca 36v5 tv
How did you detected it?
5/18/2012 5:05:30 AM • RCA 36V550T 36"... • Answered on May 18, 2012
Tv keep turning off an on what part do i need for it
Try this link www.manualowl.com Jimmy
4/11/2012 9:15:43 PM • RCA 36V550T 36"... • Answered on Apr 11, 2012
Why is my tv cutting on an off
If it is a RCA 36V550T do you hear a high pitched sound from set before you try to turn it on?The model indicated is well known for the High Voltage transformer and or a sweep transistor failing.The transistor is easy to check with a ohm meter and if shorted 100% chance it and the transformer are both bad (usually just the two parts)?
3/27/2012 5:13:17 PM • RCA 36V550T 36"... • Answered on Mar 27, 2012
2answers
Trying to figuire out if the RCA 36V550T is
That's a CRT... it's inherently analog. If you use the right equip, you could get a digital signal to display on it, but the picture would still be analog.
8/9/2011 2:27:26 PM • RCA 36V550T 36"... • Answered on Aug 09, 2011
Rca tv model #36v550tyx1 no picture but green
that need more information for it.
6/6/2011 6:14:29 PM • RCA 36V550T 36"... • Answered on Jun 06, 2011
I hooked up my computer to the tv and the desktop
Try going into your display properties, and adjusting from there. Right click anywhere on your start screen, and select properties. Then select display properties. Hope this is helpful
4/28/2010 4:52:54 PM • RCA 36V550T 36"... • Answered on Apr 28, 2010
TV zoomed in
Look at your remote or On-screen menus for ratio settings. The remote might say zoom or ratio. The menus will probably have it under video and then Aspect Ratio. You'll probably need to hit go through several settings to get to the correct ratio. (some choices are 4:3, 16:9, Full-screen - the best choice depends on the set and the source video)
I hope this helps.
(my remote (slightly different TV) has the zoom just above mute so I hit the wrong button often.)
4/24/2010 5:28:33 AM • RCA 36V550T 36"... • Answered on Apr 24, 2010
TURNING ON
put batteries in the remote
7/6/2008 5:44:04 PM • RCA 36V550T 36"... • Answered on Jul 06, 2008
E-Prong
circuit city
1/22/2008 1:23:00 AM • RCA 36V550T 36"... • Answered on Jan 22, 2008
0answers
Samsung TXN2726 Televison Remote
hiya sounds like the remote has de-registerd it self with the telly. all you need to do is find out the infered codes for that telly and do the [set] - [TV]combo with the numbers after.
10/2/2007 9:10:22 PM • RCA 36V550T 36"... • Answered on Oct 02, 2007
NEED HELP !!!!! remote will not work (original nor directv programed)
If the front panel lock is on, you will need a working original remote (or a universal remote properly programmed for RCA) to turn the set on. The IR receiver is next to the buttons on the fromt but the RCA IR receivers are very reliable, and I have yet to see a bad one in a modern RCA TV. Once you turn the set on by remote, you can enter the menu and turn the FPA off.
9/17/2007 2:37:25 AM • RCA 36V550T 36"... • Answered on Sep 17, 2007
2answers
Powers up but shuts down when play button is pressed RCA YLG43E
Try to check the power supply output side where anything could came into contact with positive and negative line for which when you press play button then it shuts down.
3/25/2024 6:44:15 PM • RCA Televison &... • Answered on Mar 25, 2024
Black and white screen only on DSTV?
RCA video cables handle analog signals. HDMI cables carry digital video signals. You need a converter. If you are using a component video converter, check if you swapped two of the three RCA video cables. (There are some A/V projectors that can do the translation of RCA and HDMI internally. Most TVs do not.) I hope this helps. Cindy Wells (One of my family's TVs used a dongle to condense the analog video signal to a single port, swapping blue and green gave a black and white output, IIRC.)
3/24/2024 11:03:58 PM • RCA Televison &... • Answered on Mar 24, 2024
I have an RCA re20qp80 remote that the mute button doesn't work
Most modern tv remotes are not normally designed to be repaired. You will possibly need to replace it. there are plenty of cheaper after market version that will do the job just as well. Your other option, and yes I know this is a silly answer, when you want to mute the TV is to simply press the volume down button to zero then turn it back up when you want sound.
2/23/2024 10:21:26 AM • RCA Televison &... • Answered on Feb 23, 2024
2answers
How to connect rca vr667hf to tv
you will need to rind RCA to whatever input is on your tv google RCA to HDMI copy and paste link for manual https://www.manualslib.com/manual/313476/Rca-Vr677hf.html#manual
2/18/2024 4:51:27 PM • RCA Televison &... • Answered on Feb 18, 2024
RCA 36V550T 36" TV Logo
21 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
need help remote will not work
  • Televison & Video
