20 Most Recent
Broksonic SC20145 20 in. TV/VCR/DVD Combo Questions & Answers
I lost my remoe and
U should turn on the tv ON manually by the tv power button to get the tv ON and used all the codes that was provided by the universal remote user manual for the ur tv brand Broksonic.U must follow the directions carefully and enter each codes correctly,the correct universal codes for tv is enter,ur tv will able to work by the tv universal remote power button will able to turn the tv off/on of the tv set.If none of the tv universal codes that was provided by the universal remote user manaul for ur tv brand Broksonic don't work.Just return the thing to Walmart and get ur money back.Try website like Remotes.com to buy the tv original remote,than 100% will work for ur tv set.
8/17/2011 5:48:19 PM •
Broksonic...
Answered
on Aug 17, 2011
DVD is stuck in the TV set.
there should be a small hole next to the dvd tray where you can insert a straightened out paper clip and manually push the tray open.
1/15/2011 2:51:04 AM •
Broksonic...
Answered
on Jan 15, 2011
Why does a TV remote control quit working?
Assuming you have changed the batteries, you might try blowing around the edges of the keys with "canned air" spray.
Most likely you can go to a drug store and buy a "universal" remote that will serve as a cheap replacement.
NOTE WELL: check out the "universal" remote's labeling and online to make sure it is compatible with your set BEFORE buying.
9/16/2010 7:13:23 PM •
Broksonic...
Answered
on Sep 16, 2010
Remote Control Stopped working
We have the same problem with remote controls for a Panasonic TV - we have two identical Panasonic remotes that both worked, but now neither one does. Any ideas out there? Thanks.
3/25/2009 10:31:45 PM •
Broksonic...
Answered
on Mar 25, 2009
No sound on 1 channel
Check Your Audio Setting While On That Channel Access Your Tv Menu And Find Audio Change Between Sap Stereo And Mono Probably Will Fix It May Not.
1/6/2009 3:13:30 AM •
Broksonic...
Answered
on Jan 06, 2009
Broksonic DVD/VCR
First of all if it's just the fact that your DVD players tray won't open on your tv then you'll have to manually open it. Before you even attempt to try and pry the player open you would (the next time you can) find out where the tray gear is that opens and closes it. It would be the big black gear I assume. Once, you find that then you'd have to use a flat ridged object (like say a plastic knife) and slide it in and push on the gear until it opens. But, if you're having problems with playing the disc that's a whole different story. Other than that you could just buy a different TV. This time with a seperate dvd player. Those are easier to fix.
11/26/2008 9:17:19 AM •
Broksonic...
Answered
on Nov 26, 2008
