20 Most Recent RCA HDLP50W151 50" Rear Projection HDTV Questions & Answers
2answers
I have a RCA Scenium HDLP50W151YX1 that has distorted Color (Bad Picture)
I am parting out my tv it was playing good when I shut it off we got a wall hanger we don't need this tv let me know what part you need I'll sale them cheap 2705898074 call me if you want
3/5/2019 6:19:14 AM • RCA HDLP50W151... • Answered on Mar 05, 2019
I have a HDLP50W15, I changed the lamp a year ago.
It is a ballast job for sure. It is located around the bulb since it generates the power to excite the bulb to giving off light. Try to utube the procedure and you might get lucky with a how to video.
8/26/2017 2:28:27 AM • RCA HDLP50W151... • Answered on Aug 26, 2017
The picture went blank on
When was the last time you changed the bulb for the projector? has this gone bad? If the bulb needs changed, consult your manual for instructions and if the bulb is good let us know.
1/6/2016 2:16:12 AM • RCA HDLP50W151... • Answered on Jan 06, 2016
3answers
Rca hdlp50w151 screen removal
Remove the 3 screws about 3 inches in on the back side of the speaker cover on each side. pull out and slightly upward on the speaker cover to remove. supsupport the cover if you do not want to disconnect the ground and button control cables. Remove the screws on the top and side rear panel to front frame/screen cover. tilt the screen cover out about 12 in at the top and lift up. Reverse the procedure to reinstall.
10/11/2015 6:13:30 PM • RCA HDLP50W151... • Answered on Oct 11, 2015
0answers
My D52w23 makes noise and wont turn on keeps
Does it sound like a sharp short squeal, or a soft wispy whine that coincides with the blinking power light 3 times then stops when the power light each time? If so respond to this same post and I will assist you with the issue.
12/7/2013 2:15:32 AM • RCA HDLP50W151... • Answered on Dec 07, 2013
At start up, tv comes on, sound and picture. A few
Your Lamp needs to be replaced.
Mats Electronics 1-800-628-1118 they have Lamps for $89.95
8/22/2013 5:01:32 PM • RCA HDLP50W151... • Answered on Aug 22, 2013
My RCA Scenium looks like there is a shadow of another channel on the screen
I am scraping out my tv all boards are good the tv played great just wanted a wall hanger if you need a part call me 270 589 8074
8/10/2013 5:29:56 PM • RCA HDLP50W151... • Answered on Aug 10, 2013
HELP! 50 inch projection RCA HDTV. Turn it on sometimes minutes later, sometimes hours later the picture will go black with sound on once or twice and then it will power itself off entirely. None o
I got all the components you need for your tv I'm parting out mine it was oar king break when I turned it off we bought a wall hanger if you need parts call 270 589 8074
8/10/2013 5:25:52 PM • RCA HDLP50W151... • Answered on Aug 10, 2013
RCA Light Tunnel
I have one for sale 75.00 2705898074
8/10/2013 5:17:27 PM • RCA HDLP50W151... • Answered on Aug 10, 2013
RCA HDLP50W151 it turns on and once it warms up it turns off?
The first thing that you need to do is clean it out. There can be a problem like you are talking about due to dust and dirt in the unit. It thinks there is an overheat condition. While you are cleaning the unit, check and make sure that all the fans that are inside are working. They can wear out.
10/28/2012 3:09:58 PM • RCA HDLP50W151... • Answered on Oct 28, 2012
Picture darker in middle
The model indicated is a DLP type set and answer is based on that model number.Either a issue with the actual lamp (unlikely but possible) or a issue with the Optical light engine this set uses--possible damage from heat the lamp creates when it shines into the engine.
4/30/2012 6:54:46 PM • RCA HDLP50W151... • Answered on Apr 30, 2012
2answers
RCA dlp 50"
Buzzing is usually indicating the color wheel is defective. Or it could also be the lamp fan malfunctioning as well. My quess would be the color wheel as thats a fast moving part which is prone for bearing failure.
4/22/2012 3:14:50 PM • RCA HDLP50W151... • Answered on Apr 22, 2012
RCA HDLP50W151 50" Rear Projection HDTV Logo
214 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
rca hdlp50w151 screen removal
  • Televison & Video
