20 Most Recent
RCA HD61THW263 61" Rear Projection HDTV Questions & Answers
RCA HD61THW263
If the picture comes on a its blue the lamp is ok. If you dont't get a menu then you really have a problem. A technician can bring up test patterns on this set that can tell you what the problem is.
Have an infocus sp61md10 same
When it turns off, what is the status of the LED at the front? Does it blink or stay on? If it blinks then how many times does it blink in between each pause? Please provide this info so that we can continue with the diagnosis.
Lightning Problem
I HAVE A 61" RCA INFOCUS ALL THE LIGHTS IN FRONT OF THE TV IS BLUE YOU UN PLUG IT AND PLUG IT BACK IN IT STAYS BLUE. YOU CANT TURN IT OFFOR ON
Rca hd61thw263 61 in. dlp
Seems a lightning strike took out my bulb
eventhough i have a surge protector.
after replacing the bulb perhaps 1 hour later a shadow began to appear at the top of the screen and progressed slowly down until only the edges are visible.
please can you help?
REMOTE NOT WORKING NO AUDIO AND NO PICTURE
Most times this unit goes dead because either the lamp is bad or need to be reseated. Pull the from cover off to find the lamp. First pull out the lamp, clean the contacts on the lamp by just wiping them with a soft cloth and reseat the lamp. Re-assemble and see if that helps. If not you will need to replace the lamp.
Black and white screen only on DSTV?
RCA video cables handle analog signals. HDMI cables carry digital video signals. You need a converter. If you are using a component video converter, check if you swapped two of the three RCA video cables. (There are some A/V projectors that can do the translation of RCA and HDMI internally. Most TVs do not.)
I hope this helps.
(One of my family's TVs used a dongle to condense the analog video signal to a single port, swapping blue and green gave a black and white output, IIRC.)
I have an RCA re20qp80 remote that the mute button doesn't work
Most modern tv remotes are not normally designed to be repaired. You will possibly need to replace it. there are plenty of cheaper after market version that will do the job just as well. Your other option, and yes I know this is a silly answer, when you want to mute the TV is to simply press the volume down button to zero then turn it back up when you want sound.
How to connect rca vr667hf to tv
you will need to rind RCA to whatever input is on your tv google RCA to HDMI
copy and paste link for manual
https://www.manualslib.com/manual/313476/Rca-Vr677hf.html#manual
I Want code list for RCA 4- device universal remote
You need the TV codes not the remote ones. I would use the Remotes code search feature as the Sanyo has allot of codes and you may spend hours going through them.
Sanyo remote codes 0154 0208 0157 0280 0484 0292 0721 0011 0036 0045 0370 0068 0339 0072 0216 0104 0217 0145 0146 0156 0555 0381 0412 0009 0508 0544 0163 0799 0037 1154 0108 0159 0556 0486
Where is the fuse located on a rca flat screen tv
The fuse on an RCA flat screen TV is typically located on the power supply board near one of its corners. The power supply board is the board with an array of capacitors, resistors, and heat sinks on it . The fuse is a small cylindrical tube with metal caps and is relatively small compared to other components on the board . If you have never seen a circuit board before, finding the fuse may be tricky. You can consult the user manual for your TV if you need help locating the fuse .
TV Fuse Replacement Guide: Locating and Replacing Your TV Fuse - PointerClicker.com
Replacing the fuse should be done with caution, especially if it is soldered to the board, as errors could lead to costly damage. You can check if the fuse is blown visually or with a multimeter-like tool. If you are unsure about how to replace the fuse, it is best to seek professional help.
