Hi.
The problem is likely a defective PSU, but the TV must be tested by a technician before replacing parts.
If the TV went in standby and does not wake up, but stays in standby with diagnostic light blinking, then the TV has on protect mode after detecting a malfunction.
When this happens higher voltages from PSU (this power supply operates at different voltages) are shut down to prevent further damage.
Before calling support ensure that you have followed the indications here:
Why my TV does not start up and remains in standby.Troubleshooting basically consists in leaving the TV unplugged to drain power completely and discharge internal circuits.
The
best way to contact an authorized technician is by ringing the number
listed on the owners manual. Alternatively try Fixya directory here:
Fixya directory-
Consumer Products RepairTry first the troubleshooting proposed in link above. If that does not work, ring customer service.
Regarding
the repair cost, this depends on the part that is defective. A common
fault is the power supply, but as said this is not necessarily the problem.
For parts try
Partstore.
Regards.
Ginko.
