20 Most Recent RCA HD52W56 52" Rear Projection HDTV Questions & Answers
Picture screen leans to one side
HD52W56 D52W56 Check the link and see if the symptoms fit the problem.
12/22/2017 12:44:39 AM • RCA HD52W56 52"... • Answered on Dec 22, 2017
I have a HD50LPW142 RCA television. It makes a squeaking noise upon being turned on and remains that way until turned off. The picture is working properly. I was told replacing the light bulb would re
There are actually 3 light guns (or as you were told, "light bulbs") in your projection TV, and if one of the guns was failing and making the noise, you only had a one in three chance of fising the problem if you replaced only one "light bulb".
11/6/2017 7:15:28 PM • RCA HD52W56 52"... • Answered on Nov 06, 2017
50 or 52 inch RCA HDTV about 10 yrs old the power light blinks 9 times then 5 times then 9 times and won't go off unless unplugged, won't turn back on
i have seen this before and sorryy to say if unplugging for 5 or more min and that dose not fix it may need to be replaced not many people fix them these days but not impossable
6/5/2016 5:42:51 AM • RCA HD52W56 52"... • Answered on Jun 05, 2016
LED PANAL LIGHT IS DIM
There is no LED on a rear projection television. There are three projection tubes (RED GREEN AND BLUE) and those tubes are mounted in the set and project the image to the mirror and then to the lenticular screen. The issue with brightness could b one of several things. Dust and film accumulate on the tubes and mirror. This causes the image to fade, Also since it has TUBES they age. They are getting hard to find too. The other thing is the adjustments on the set can change over time. There are brightness and contrast settings inside the set that have to be changed and reset after long years of use.
5/17/2016 2:42:13 PM • RCA HD52W56 52"... • Answered on May 17, 2016
Rca sound and menu problems
Here at my shop we see this problem with these rca sets. The processor is seeing a command from the keyboard or the ir sensor. The most likely cause is a faulty keyboard cuircit board. And replacing is the best coarse of action. To make sure its the problem I remove the keyboard cuicit board and see if the problem goes away. I just use the remote to control the tv, u can also do this until the part arives To get the part you need to know the entire model number. It will be on the sticker in the back in small letters hd52w56yx1 or yx30 or something to that extint. i get most of my rca parts from union electroncs or just let me know and i can look up the part number for you
3/5/2016 9:07:44 PM • RCA HD52W56 52"... • Answered on Mar 05, 2016
Looking for a schematic diagram of circuit board
hi'
11/28/2015 1:59:05 PM • RCA HD52W56 52"... • Answered on Nov 28, 2015
I have a RCA projection tv hd52w59 theres a partail static screen and a red green and a blue line in the middle
is the line horizontal or vertical ? you have some sort of a deflection problem its either vertical failure or the yoke return circuit on the horizontal has a failure
6/6/2014 6:30:25 PM • RCA HD52W56 52"... • Answered on Jun 06, 2014
Why is the picture is to high or big and cuts off the heads of the people on my RCA HD52W59 rear projection HGTV
its setting the screen format . take the factory remote and by using the cursor left or right you can scan the size changes
5/29/2014 3:49:49 AM • RCA HD52W56 52"... • Answered on May 29, 2014
No sound no pic
This is a CRT set. Likely no HV, maybe bad flyback. . Possibly bad capacitors on SMPS area of deflection board too.
5/8/2014 4:09:51 AM • RCA HD52W56 52"... • Answered on May 08, 2014
I hit picture size and it says not available
May have a pincushion issue is not adjustable, or programming set to one specific size. Sometime this does occur with digital programming.
5/8/2014 3:31:45 AM • RCA HD52W56 52"... • Answered on May 08, 2014
0answers
Heard pop sound picture went
Your backlight went out. Manual should tell you how to change it
10/17/2013 10:09:02 PM • RCA HD52W56 52"... • Answered on Oct 17, 2013
No color blue
HOW DO YOU FINE TUNE THE FINE TUNING THE PICTHER
9/3/2013 1:20:24 AM • RCA HD52W56 52"... • Answered on Sep 03, 2013
Tv volume
Check its speaker first. If found OK, check and replace damaged component/s at its audio output section circuit. If you are not sound in electronics, contact any service technician.
7/13/2013 2:19:56 PM • RCA HD52W56 52"... • Answered on Jul 13, 2013
RCA HD52W56 52" Rear Projection HDTV Logo
450 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
hit picture size says not available
  • Televison & Video
