20 Most Recent RCA P61950 61" Rear Projection Television Questions & Answers
My rca home theater premiere 60" rear -projecton tv changes its channels without me doing anything
Ive seen that over the years . on the front of the set there are the push button switches . one of them have failed on the board . the tact switches can be replaced . if you can solder and have the skill and ability . or the other option is since most people live by the remote and do not get up to turn there set on or change channels . if you were to take the back off of the set you would look at the top center of the light box . there you will see a board with some cables running to it and since we don't have a model number from you i can not tell you exactly which cable it is but it will run to the push button board just unplug that there and you can use the remote and you should return to a normal operation .
1/7/2015 3:09:26 PM • RCA P61950 61"... • Answered on Jan 07, 2015
It was turning on fine
Hi, most of the time with these types of sets the convergence IC's goes bad (2) with some low ohm resistors and or low amp fuses with some cold solder connections....
3/28/2011 7:56:05 PM • RCA P61950 61"... • Answered on Mar 28, 2011
Sound but no picture
go to menu , then sap , or second language , be sure its set on english .
10/11/2010 11:47:35 PM • RCA P61950 61"... • Answered on Oct 11, 2010
What bulbs will replace mine?
Go to partstore.com, enter the model and it will show you a list of bulbs and various other parts. The bulbs run about $200-300 depending on color.
10/1/2010 4:52:49 PM • RCA P61950 61"... • Answered on Oct 01, 2010
I have a 61
Hi there, I am having the same problem with mine. Just wondering if you were able to figure out the problem and solution??
10/1/2010 4:50:24 PM • RCA P61950 61"... • Answered on Oct 01, 2010
Rca p-61950 rear projection tv has pic but no
check your rear of the tv. there is a switch for external speakers.
9/16/2010 12:21:32 AM • RCA P61950 61"... • Answered on Sep 16, 2010
2answers
DOUBLE IMAGE
get a remote for it,,,,
8/27/2010 8:28:47 PM • RCA P61950 61"... • Answered on Aug 27, 2010
Trouble with rca rear projection tv
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
6/6/2010 5:24:02 AM • RCA P61950 61"... • Answered on Jun 06, 2010
I need a new glass front and trim to hold in>
Find a TV repair shop near you and see if they happen to have this particular model they use for parting out! Why buy new when used will do in this case. Thanks for asking!
5/24/2010 4:04:17 AM • RCA P61950 61"... • Answered on May 24, 2010
I have a rca 61
The problem is most likely dust on the projection lenses.
3/10/2010 3:21:12 AM • RCA P61950 61"... • Answered on Mar 10, 2010
Front panel will not work right no power button
walmart RCA universal remote- less than $15
12/10/2009 5:37:42 AM • RCA P61950 61"... • Answered on Dec 10, 2009
How to get into service mode
the colors green pink and are vivid on the screen and the picture is out of focus.
5/11/2009 2:00:38 PM • RCA P61950 61"... • Answered on May 11, 2009
I have no power going to tv no red light on front
hiya
this is a warning that it needs a new lamp
Rik
2/27/2009 12:38:29 AM • RCA P61950 61"... • Answered on Feb 27, 2009
2answers
Powers up but shuts down when play button is pressed RCA YLG43E
Try to check the power supply output side where anything could came into contact with positive and negative line for which when you press play button then it shuts down.
3/25/2024 6:44:15 PM • RCA Televison &... • Answered on Mar 25, 2024
Black and white screen only on DSTV?
RCA video cables handle analog signals. HDMI cables carry digital video signals. You need a converter. If you are using a component video converter, check if you swapped two of the three RCA video cables. (There are some A/V projectors that can do the translation of RCA and HDMI internally. Most TVs do not.) I hope this helps. Cindy Wells (One of my family's TVs used a dongle to condense the analog video signal to a single port, swapping blue and green gave a black and white output, IIRC.)
3/24/2024 11:03:58 PM • RCA Televison &... • Answered on Mar 24, 2024
I have an RCA re20qp80 remote that the mute button doesn't work
Most modern tv remotes are not normally designed to be repaired. You will possibly need to replace it. there are plenty of cheaper after market version that will do the job just as well. Your other option, and yes I know this is a silly answer, when you want to mute the TV is to simply press the volume down button to zero then turn it back up when you want sound.
2/23/2024 10:21:26 AM • RCA Televison &... • Answered on Feb 23, 2024
2answers
How to connect rca vr667hf to tv
you will need to rind RCA to whatever input is on your tv google RCA to HDMI copy and paste link for manual https://www.manualslib.com/manual/313476/Rca-Vr677hf.html#manual
2/18/2024 4:51:27 PM • RCA Televison &... • Answered on Feb 18, 2024
2answers
I Want code list for RCA 4- device universal remote
You need the TV codes not the remote ones. I would use the Remotes code search feature as the Sanyo has allot of codes and you may spend hours going through them. Sanyo remote codes 0154 0208 0157 0280 0484 0292 0721 0011 0036 0045 0370 0068 0339 0072 0216 0104 0217 0145 0146 0156 0555 0381 0412 0009 0508 0544 0163 0799 0037 1154 0108 0159 0556 0486
2/2/2024 11:35:38 PM • RCA Televison &... • Answered on Feb 02, 2024
RCA P61950 61" Rear Projection Television Logo
17 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
  • Televison & Video
