20 Most Recent Symantec Norton AntiVirus 2004 - (Open Box) for PC Questions & Answers
Hello, Go here and create and account and download from here.
Something went wrong Norton Secure Login
Symantec Norton... | Answered on Oct 24, 2015
You can't image a primary partition while the system is running. There are system files that are in use and are locked for your protection.
Also, your program is very old--try to update it.
If you are using Windows 7, you can make an image from the backup utility.
Symantec Norton... | Answered on Mar 12, 2011
You should use a more recent version of Norton. In 2004, Windows 7 didn't exist. That's probably the problem.
Symantec Norton... | Answered on Aug 25, 2010
OK, what is the exact problem that you are having with Norton AntiVirus 2004 for the PC?
I am wondering if you should be using one intended for 2010 or so, rather than the 2004 version, because definitions for viruses change often. And, I always recommend the latest antivirus protection updated regularly for virus protection.
One virus protection system I use, is a FREE one from microsoft.com. Just search under Antivirus, and it will lead you to the free program from Microsoft. It's actually a very good system that gets updated daily and doesn't take up a lot of CPU time on the PCs that it's installed on.
Symantec Norton... | Answered on Aug 13, 2010
Need to reinstall Norton program manually
1. remove the Norton program with Norton removal tool (www.norotn.com/nrt)
2. clear temp and prefetch ( to clear temp type %temp% in run and to clear prefetch type prefetch in run and delete all files)
3. restart the system
4. clear all the Norton files from registry
5. clear Norton or symantec folder from application data
6. install Norton program
If you get the same issue after we reinstall manually you need to create one administrator account and install Norton program
Symantec Norton... | Answered on Jul 29, 2010
You have most likely acquired some malware that Norton did not catch (this is not just a problem with Norton, but with all virus products). Go to www.malwarebytes.org and download the latest free version. If your malware is particularly nasty, it will block this site in which case you'll have to download the software on another computer and put it on a USB drive or CD. Boot your computer into safe mode (hit F8 repeatedly upon turning on your computer until the boot menu comes up) and select Safe Mode with Networking. Once in safe mode, install and run the MalwareBytes program. Let it update (if it can) and run a full scan (will take some time). After it completes, have it remove all infected files. Now reboot the computer and let it start normally. Run a complete scan with Norton and it should start updating again with no problems.
Symantec Norton... | Answered on Mar 04, 2010
This is a billing problem on Symantec's end that neither you or we can resolve. You will have to contact Symantec (manufacturer of Norton) and ask them to kindly resolve this issue. You will have to provide proof of purchase and all that good stuff. Their contact details are located on this web-page. As long as you paid for the Norton 360, everything is bought and paid for until the expiration date and shouldn't expire prior to that date (Unless this is a new business practice of Symantec, wouldn't surprise me you know).
I just have to say this, though. You would be better off with ESET's Smart Security. Uses less system resources and does a much better job defending your system from attacks.
I hope you get the issue resolved.
Symantec Norton... | Answered on Feb 26, 2010
Well you need to contact to your dealer to cancel both of the orders, or you can contact to Norton, please follow the below link to contact them -
http://www.symantec.com/feedback/contactus.jsp
Good Luck!!
Thanks
Symantec Norton... | Answered on Jan 02, 2010
Hi ya .. I was also getting the same thing and followed that symantec recommended remove and reinstall, only to later find that thier is a hotfix and I found it on a blog. check it out
http://serviceframeworkfix.blogspot.com/
Symantec Norton... | Answered on Aug 24, 2009
STEP 1 Uninstall the Norton product in which the error occurred kb_tip.gif Before you continue, make sure that you have the installation CDs or downloaded installation files for any Norton products that you want to reinstall. 1
Click Start > Control Panel.
Double-click Add or Remove Programs.
Click the name of the Norton product. You may need to use the scroll bar to view the entire list.
Depending on your version of Windows, click Add/Remove, Change/Remove, or Remove, and follow the prompts.
5
Restart the computer.
STEP 2 Run the Microsoft Windows Installer Clean Up utility 1
Download the Windows Installer Clean Up Utility. DOWNLOAD
Click Save to download the Msicuu2.exe file. Save the file to your desktop.
If you see a prompt, click Close.
Double-click the file and then follow the steps in the Setup wizard to install the utility.
5
Click Start > All Programs > Windows Install Clean Up to run the utility.
6
Press and hold down the Ctrl key, while you click all entries in the list that begin with the following text: - CC - cc - Norton - Symantec - Sym - MSRedist
7
Click Remove.
8
STEP 3 Reinstall the Norton product that you uninstalled 1
Do one of the following:
  • If you purchased a CD, insert the CD into the CD-ROM drive, and then click Install Product Name, where Product Name is the name of your Norton product.
  • If you downloaded your copy of Norton product, double-click the file that you downloaded. Unless you saved it elsewhere, the installation file is on the Windows desktop.
Follow the on-screen instructions.
Symantec Norton... | Answered on Jul 04, 2009
now the symantec is not supporting this version of the norton ghost,you have to get the upgraded version of the norton ghost 14.0
Symantec Norton... | Answered on May 04, 2009
Call them and explain your situation. The phone number is in this list. Good Luck→
http://www.hardtofind800numbers.com/listings/s.htm
Symantec Norton... | Answered on Mar 27, 2009
go to the command prompt and type the regedit
>left click HKEY_Local_Machine>software>symantec>ccpdlcdelete the kstore>now try to activate the product
Symantec Norton... | Answered on Mar 16, 2009
If you're a home user I would suggest uninstalling Norton as you have an old version and install AVG Anti Virus and Zone Alarm firewall. These are both free for home users and have more modern engines.
You should also notice a speed improvement on your PC as Norton products can be quite rescource hungry.
Regards
Andy
Symantec Norton... | Answered on Mar 09, 2009
Sounds like Outlook Express is set to read the headings only. If you click on it it should open. Unless your drive is full.
You can install Windows Live Mail and it will upgrade your e-mail in Outlook Express to the new program. The download is free and available at Microsoft.com.
As far as the D drive goes, you should change some of your program settings to put files on the C drive. If you loaded up programs on your D drive, unistall them and load them to you C drive.
There might be some folders you can copy from the D to C drive but if it is a program, it will no longer work properly. Use your best judgement when dragging and dropping them from one drive to the other.
Symantec Norton... | Answered on Feb 26, 2009
try symantec's own ftp server, download and run this
Symantec Norton... | Answered on Feb 06, 2009
Download RevoUnistallers. Here is the link.
http://www.ask.com/bar?q=REVO+Unistaller&page=1&qsrc=2873&zoom=&ab=0&u=http%3A%2F%2Fwww.revouninstaller.com%2F
This has gotten rid of alot of programs for me it also gets all the hidden files that add and delete do not
Symantec Norton AntiVirus 2004 - (Open Box) for PC Logo
Popular Tags
85 questions posted
Top Symantec Computers & Internet Experts
Ekse
Lisa
Lisa
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Symantec Computers & Internet
Most Popular Question
occurs when used norton
  • Computers & Internet
