20 Most Recent
RCA DRD430RG DirecTV DTV Receiver Questions & Answers
Hello! I had channal CCTV4 before,Now it doesn't
DirecTV has cancelled Jade World and TVB on 11-18. These are arguably the most popular Cantonese stations. Dish Network is carrying TVB and Jade World so call 877-342-2104 to get signed up today!
Turn it on..fine for 15
Try to input another source(DVD Player) to the same jack you are using as input for your set top box to determine where the fault came from.
If the symptoms does not appear, this is an indication that the fault came from the set top box itself. You should contact your service provider to check the condition of the box and confirm if it is already faulty and need a replacement.
Let me know if the symptoms still persist even with the DVD as the input.
Jdvillanueva
Remote will not work
you would need to contact directv at 800-531-5000 and if programming it did not work, and setting it to default did not work, you may need a new remote. remote will cost about $15 unless you have the protection plan then it should be free depending on some circumstances.
My directv remote will not change the channel
Replacing the batteries if you have not already done so. Make sure the batteries are inserted correctly. If remote still does not work I recommend calling dtv and asking for a replacement remote that is available for purchase. Call 1 800 531 5000 for customer service. Call from the phone number that is listed on the account for easier access to an agent.
My directv d12-300 receiver won't take the
Because the reciever has a internal issue. you will have to call directv and get a tech to bring a new one. to redo, turn of reciever and when you see the blue light power press 02468/
H 20 Direct TV HD Receiver Requires frequent reset
the cabling can go bad. often, it is the hdmi cable that goes bad.
from what i'm aware of directv they can reimburse you up to 15 or $20 if you have to purchase cabling if you have the protection plan. may want to double check w/ them to find out if this is still the case. hope this helps.
