20 Most Recent
Mitsubishi 1.44M 3.5 34Pin Floppy Drive (MF355F3250) Floppy Drive Questions & Answers
Where can i get his part ? Mitsubishi FDD unit . Type fcu6-fd221-1
It may be difficult to find a replacement FDD (floppy disk drive) unit for a Mitsubishi system, as floppy disk drives are no longer commonly used in modern computer systems.
One option you could try is to search online marketplaces, such as eBay or Amazon, for a used or refurbished FDD unit that is compatible with your system. You may also be able to find a replacement unit through a specialist computer repair shop or electronics store.
Alternatively, you may want to consider upgrading to a more modern form of storage for your systems, such as a USB flash drive or a hard drive. These options may offer more capacity and faster data transfer speeds than a floppy disk drive.
I hope this information is helpful! Let me know if you have any other questions.
MF355H - 262MG
I sell a replacement drive for this one used in Yamaha Disklavier Pianos on E-bay. I am getting ready to list 9 of them, The address to my E-bay store is
https://www.ebay.com/str/dunnbrothersplayerpianomusic
Where can I find cable
Hi.
The Mitsubishi is a standard
3 1/2 1.44MB HHT NO BEZEL floppy drive. Its pinout is the standard for this kind of floppy drive.
Here the pinout:
PIN /FUNCTION
1 Ground
2 /REDWC
3 Ground
4 N/C
5 Ground
6 N/C
7 Ground
8 /Index
9 Ground
10 /MOTEA
11 Ground
12 /DRVSB
13 Ground
14 /DRVSB
15 Ground
16 /MOTEB
17 Ground
18 /DIR
19 Ground
20 /Step
21 Ground
22 /WDATE
23 Ground
24 /WGATE
25 Ground
26 /TRK00
27 Ground
28 /WPT
29 Ground
30 /RDATA
31 Ground
32 /SIDE1
33 Ground
34 /DSKCHG
Here a page showing the floppy drive pinout in more detail.
Regards.
Ginko.
Unable to get parallel port
After you have hooked the drive to your computer you need to go to the manufacturers website and download a driver to make it recognizable to your computer.
I have an issue of my car mitsubishi spacegear,,4m40 year 1994..why does A/T blinking at the dashboard??
It sounds like you are experiencing an issue with the automatic transmission (A/T) indicator light on your dashboard. The A/T indicator light is designed to alert you to problems with the transmission system. If the light is blinking, it may indicate that there is a problem with the transmission and it should be checked as soon as possible.
There could be a number of reasons why the A/T indicator light is blinking on your Mitsubishi Spacegear. Some common causes include:
- Low transmission fluid level: If the transmission fluid level is low, it can cause the transmission to malfunction and the A/T indicator light to blink. Check the transmission fluid level and add more if necessary.
- Faulty transmission control module: The transmission control module is responsible for controlling the transmission. If it is not functioning properly, it can cause the A/T indicator light to blink.
- Wiring issues: If there are problems with the wiring in the transmission system, it can cause the A/T indicator light to blink.
I recommend having a mechanic diagnose the problem in order to determine the cause and recommend the appropriate repair. I hope this helps! Let me know if you have any other questions.
Question about Mitsubishi D80
Mitsubishi D80not told how connectedNO PC toldno OS Told (windows or mac or what) XP to W8 is yes.no connections told.when did it last run googe, last week, last year or last decadereal model; this????CP-D80DW>> color printer?USB cable.? get the makers software , lost the CD of software ?windows XP and w7/8 is stated in your manualusing that?got front panel ALARM LED errors, page 20?read page 23, what to do before calling for help? do that?do the cleaning steps
https://www.manualslib.com/manual/774805/Mitsubishi-Electric-Cp-D80dw.html?page=24&term=clean&selected=1#manualand up to w10 online support from maker. + OXS now.drivers seen here,the manual tells how to load that and connect USB last , never first, RTM read how to do that, and then test the printer with new ink.CP-D80DWhttps://mitsubishielectric-printing.com/en/downloads/drivers-tools
How can i watch video through my sd card on mitsubishi nr-mz50 car dvd??
Mitsubishi Electric NR-MZ50 Car Navigation System $1800 !
WHAT CAR? and YEAR<, go to MFG. web sit and get the manual first, if LOST ! IT.
What makes you think it can?>
sure hope.
WHA
open glove box and RTM? yet, unstated car.
car radio, head- in's/nAV are very dumbb(sic) as class of devices.
they only allow a limited set of formats.
you'r talking about movie file formats 100s,
The movie file, formats to try are MP4 and MKV (most common)
The manual Mz50. first. it will tell you what it supports, and no 2 car-heads work the same or have same limits,
so that means RTM read the manual then do experiments.
also some HEADs may have DRM rule limits.
that car HEAD really is not a computer, so is off topic here.
the MZ50 tuner can record to the SD card.
why not just try it.
find a small mp4 movie, and put it on the card, just 1 file
and see if you can play it,
but there are 100s of formats.
talk to Mitsubishi dealer or
try these
https://fileinfo.com/filetypes/video
It many do 1 or 2 but NEVER ALL formats.
Antifreeze overflow tank empty
Hi Kristie,if your boyfriend can walk by your car and spell antifreeze,then you have a leak.Usually,it will be your water pump,you can put newspaper or whatever you can use under your car after you have driving it and wait awhile then check paper and see where it is wet to determine what is leaking,could also be a loose radiator hose which the clamp may just need tightening up,but first add some antifreeze to your over flow container,remove radiator cap after it cools down to see how much is in radiator,add if needed.Look around radiator area,it may be leaking.You can also jack it up to look.
