20 Most Recent RCA Scenium HDLP61W151 61 in. HD-Ready Television Questions & Answers
There are capacitors on the power supply board that dry out with age. You can identify them by observing the tops of each of them. They have to be flat, not domed. Some of them may be discolored from heat. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
RCA Scenium... | Answered on Sep 12, 2017
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
RCA Scenium... | Answered on Apr 22, 2017
There are two available on ebay. Expensive. HDLP61W151
RCA Scenium... | Answered on Aug 11, 2016
rca scenium torns on but has no picture
RCA Scenium... | Answered on Jul 09, 2015
If your TV has a VGA input you can enable monitor 2 on your laptop and use the external vga output
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
RCA Scenium... | Answered on Nov 25, 2014
try another input like video one or DVD or whatever you have plugged in it directly through HDMI or component, if it works it one of two things, your tuner inside the TV is damaged, or the signal from your cable is not there, bad wire or lost service.
Tony
I already answer your question
what kind and how old? sounds like it not getting signal.
The light engine should troubleshoot. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
RCA Scenium... | Answered on Sep 11, 2014
It sounds that you wish to know how to reset the lamp time after lamp replacement. If so, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. Lamp replacement procedure, and lamp time reset details are given. google.com/+GopakumarGopalan
RCA Scenium... | Answered on Nov 02, 2013
RCA Scenium HDLP61W151 61 in. HD-Ready Television Logo
211 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
rca tv
  • Televison & Video
