20 Most Recent
Fujitsu Plasmavision PDS-4221 42 in. Television Questions & Answers
Fujitsu plasma vision monitor. Pds42211 red flash 5 times, long number displayed lhs.
Visit the site named 'Electro-help' for more
details. Click this link. View it in
"Timeslide" option, which can be selected from the drop down box
menu by the [Sidebar] tag, at the top left corner of the display
window. It will make search easy. There
are more than 1100 posts to different brand TVs now. Pull up older posts there.
There is details about the blinking codes to Fujitsu Plasma Display.
11/3/2012 10:02:12 AM •
Fujitsu...
Answered
on Nov 03, 2012
I normally unplug the television
Hi.
It sounds like the same thing that is wrong with a huge number of tv's nowadays.
Your tv is suffering from capacitor failure.
These small parts control the entire tv's power system.
They act like small booster batteries, and give a large pulse to the tv to energize the screen.
Unfortunately, there is no easy fix, other than taking it to a business with specialized techs that do this type of repair.
The reason that it need specialists is because of the capacitors being very dangerous.
Even when they aren't turned on, they can still hold 100 volts or more of static charge each, so that they give a combined power output sufficient to turn the screen on.
The best two places that I have found are Fry's, and BestBuy.
Both of these companies have the specialists for this repair.
Before you pay for the repair, have them give you a quote as to what the repair cost is going to be.
You may find that it would be cheaper to just replace the tv instead of repairing the old one.
I hope this helps you understand what is going on.
Good luck to you, and have a nice day !
4/24/2011 9:08:34 PM •
Fujitsu...
Answered
on Apr 24, 2011
I ahve a fujitsu model
I doubt if its a power cord problem. Anyway you need a IEC 3 pin power cable. Try it.
3/19/2011 5:58:52 AM •
Fujitsu...
Answered
on Mar 19, 2011
Error message
My plasma display the "error message condition 1" and red flashing light start blinking and TV screen shut down. Who can halp me to fix the problem??
5/11/2010 5:40:48 PM •
Fujitsu...
Answered
on May 11, 2010
I'd like to connect my fujitsu 42
Take a SCART lead and connect the output from the SKY box and connect to anyone of the SCART sockets on the TV. Alternatively take the digital out from the Sky box to a digital input on the TV. The necessary connection wires can be obtained from most TV Retailers, Electrical Chain Stores, Some PC dealers, online at eBay, etc. Direct Digital connection will give the best quality picture and if you use a SCART cable then make sure it is high quality thick shielded cable and gold flashed connectors as there are many inferior products out there.
10/24/2009 6:16:49 PM •
Fujitsu...
Answered
on Oct 24, 2009
RED LIGHT FLASHING NO PICTURE
Hi, Power your HDTV off and power back on, if the problem persist the your power supply board is faulty. If your device falls within the warranty period then you just might have to send it back to the manufacturers and if it does not fall under that period then you will have to carter for the cost of replacement. Regards
8/31/2009 10:59:33 PM •
Fujitsu...
Answered
on Aug 31, 2009
Fujitsu Plasma 42' approx 4 yrs old
HI , i have the same problem . it is either the power supply unit or the plasma display panel . I am problem solving it currently . generally the cost is about $1000 (aus) to fix . it is worth doing as fujitsu are outstanding plasmas .
if u need service manual pls email me at
[email protected] and will send service manual .it has the the checks to do so u know which part needs replacing . U need some experience to do the checks
hope this helps
12/21/2007 10:04:16 PM •
Fujitsu...
Answered
on Dec 21, 2007
