20 Most Recent
Line 6 POD HD400 Guitar Multi Effects Processor Questions & Answers
Hd400 power
Line 6 has a network of authorized repair centers listed on their site. Due to the complexity of the device and the possibility of needing specialized parts, i suggest t you find the repair center nearest you and have them look into it.
Just purchased a new Line 6 HD 400 from the local
I've had both very good and very bad customer service from Line 6 over the years, Personally, Id take it back to GC and have them explain what you need.That way if it's a case of a defective item, they can replace it on the spot,
Comment fair le download
Well you may follow the link below to get your manual -
http://cachepe.zzounds.com/media/Line6PodHD400QuickStart-12fd8b27f633e744690f694ab6a375fc.pdf
Good Luck!!
Thanks for using FixYa!!
Hi , Just purchased an HD400 today . When powered
This sounds like a power supply problem. SInce the unit is brand new, exercise your warranty immediately. Don't mess with it and risk voiding the warranty.
If YOU supplied the power adapter, that is LIKELY the problem. This unit take one that is capable of 3 amps. (2.5 amps minimum) Most pedal adapters will NOT work with this unit as they don't have adequate current output.
Line 6 Low Down 400 bass guitar head
Make sure the volume and master volume are turned up. Try the amp with a different cabinet and a known good speaker cable. If you get sound, it's your speakers or your speaker cable.
If still no sound, you need your amp serviced.
10/20/2018 1:02:56 AM •
Line 6 Music
Answered
on Oct 20, 2018
