20 Most Recent
Chauvet Intimidator Spot 250 Moving Light Stage Club Dj Questions & Answers
We have 2 intimidator 250
We can only guess at the cause without tearing into the unit. My educated guess is that either the cable to the color step motor has either come loose or a wire is broken in the cable. SInce the wires go through a flexure point, that MIGHT be where the problem is... the only way to tell is to do detailed troubleshooting of the unit.
9/5/2011 4:34:38 AM •
Chauvet...
Answered
on Sep 05, 2011
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM •
Music
Answered
on Feb 07, 2024
No or very little sound from Fender passport
Depending on the model, there are four around that date, it could be the insert jacks are tarnished reducing the signal flow between the pre amp stage and digital power amplifier. It could be the power amplifier has failed. It could even be customer error in wiring.
This assumes there is the correct level of signal entering the input sockets of course.
12/31/2023 8:25:12 AM •
Music
Answered
on Dec 31, 2023
