20 Most Recent Casio Privia Px330 Px-330 88 Key Digital Piano New Questions & Answers
https://shema.info/en/service-manuals/3311-servis-manual-3311.html
Casio Privia... | Answered on Jan 02, 2019
You ay have to edit a rhythm and save it as a "user defined rhythm". During editing the volume of each part can be defined with vol. level ranging from 0-127.
Please read the manual.
Metronome volume can be easily changed by just holding the metronome button.
Casio Privia... | Answered on Aug 12, 2014
Newer Casio models that have "class compliant" USB interfaces such as the PX-330 would work (plug and play) since they now have "class compliant" drivers.
Unfortunately PX-300 is an older model that would need specific drivers and Casio only made drivers for Windows PCs.
Casio don't supply PX330 drivers for IPAD.
Get a Windows 8.1 tablet or connect PX330 to a desktop PC and use IPAD to Remote control that PC.
Casio Privia... | Answered on Aug 11, 2014
The Casio Privia 410r has two pedal jacks at the back. One is the sustain pedal, the other is the soft/sus jack. Please use the other jack if you want to use sustain pedal. Only 1 of the 2 jacks can be used.
However, if you have the optional sp30a pedal which plugs UNDER the piano instead, then only can you have 3 different piano pedals.
Casio Privia... | Answered on May 18, 2014
If anyone using a wireless guitar setup is close to it when playing, can do that.
Casio Privia... | Answered on Feb 28, 2014
NO! Usually an electrolytic capacitor is defective.
Casio Privia... | Answered on Dec 17, 2013
Plug a set of headphones into one of the PHONES jacks on the left side of the unit.
Turn the Keyboard off the press and while holding down the [TONE] AND [FUNCTION] buttons power on the keyboard. Wait until all reset is done.
No - the fuse is inside the keyboard. Or at least it should be. On your particular model have a look on the underside of the keyboard (where your knees go).
Casio Privia... | Answered on Nov 26, 2013
This is a problem with one of the two contacts for that key. The contacts close at different times as the key is depressed and the time it takes between is measured as velocity which is used to control the loudness as in a regular piano. The contacts are conductive rubber pills. After a lot of dis-assembly you can clean them with 99% isoprphyl alcohol and Q Tips. Clean both the pills and the circuit traces on the board they are pressed against. Be very careful of the ribbon cables between the halves of the case.
Casio Privia... | Answered on Nov 04, 2013
Casio Privia Px330 Px-330 88 Key Digital Piano New Logo
42 questions posted
Top Casio Music Experts
Michial Gueffroy
Norman  J Weimar Jr
Norman J Weimar Jr
Ekse
Are you a Casio Music Expert? Answer questions, earn points and help others
View Most Popular
Casio Music
  • Casio Music
Most Popular Question
anyway turn board speakers off go our
  • Music
