20 Most Recent
Vizio VBR231 Blu-Ray Player Questions & Answers
How do I play DVD
According to the Vizio website, your VBR231 CAN play DVDs the same way a lot of Blu-Ray players can. The site blurb suggests the VBR231 is backwards compatible - which means your player should be able to play DVDs as well as Blu-Ray. Generally, most Blu-ray players can play DVDs if they are backwards compatible with them.
I do know Blu-Ray discs will NOT work in most standalone DVD decks.
MODEL NUMBER: VBR231
*Model Features:
* Full HD 1080p Video Playback
* Integrated Dual Band Wi-Fi - 802.11n
* 7.1 Digital Audio Output
* Backwards Compatible (see below)
*Compatibility:
* Plays Blu-ray and DVDs, Audio CDs, MP3s and Jpegs
* Multi-Channel 7.1 Audio Output via HDMI
* Playback and Enjoy Media via back USB Input (JPEGs and MP3s)
*Outputs:
* HDMI 1.3
* Component Video (YCrCB)
* Composite Video
* Stereo Audio
* Coaxial Audio
* Optical Digital Audio
I hope that helps somewhat.
A new "Tangled" movie disc not play in Blu-Ray
As newer bluray movies come out they are constantly tweeking the format. More then likely you need to update your bluray players firmware or software. There should be an option under the menu for the bluray player to update the unit of course this will require that you have it hooked into the internet via ethernet cable or wifi network.
When i put a disc
the DISK format is not recognized by your unit. Please try a different disk.
Is there a master reset for vizio vbr231
If it will not power on properly, try holding the power button in for 10 seconds. Most devices will reset with this technique. If that doesn't work unplug the device from power for several minutes and plug it back in.
Vbr231 no signal
The firmware you downloaded is flawed, there are numerous complaints about firmware updates causing all kinds of difficulties from no operation to partial access. I would contact the manufacture looking for answers.
