20 Most Recent Philips HTS5580W/F7 Theater System Questions & Answers
Philips hts3541 I need to make it region free. Help please!!
PHILIPS HTS3541 unlock1. Press Home 2. Press on R/C 8 6 8 9 3 1 0 (the 0 being multi-region)
6/20/2013 9:52:21 PM • Philips... • Answered on Jun 20, 2013
It will not play Blue Ray discs
any error messages? what happens? more info please
3/30/2013 3:01:21 PM • Philips... • Answered on Mar 30, 2013
0answers
Firmware update
Be the first to answer 11/28/2011 10:15:57 PM • Philips... • Posted on Nov 28, 2011Be the first to answer
I need to hook my
You'd probably get better digital multichannel audio if you source it from the Comcast Cable Box. Treat it like any digital source audio component and skip the TV, which adds nada to the audio by being in the loop.
On the other hand your video will be best if IT goes straight to the TV from the Box and skips the Philips. Again, nothing gained and more possibly failing interconnects if it routes to the HTS.
6/23/2011 10:51:26 PM • Philips... • Answered on Jun 23, 2011
I just purchased a Philips
There is no software update as it is already able to play BluRay 3D as detailed in the Manual.
Before you start, make sure that:
• your TV is a 3D TV, and is connected
to your home theater through HDMI,
• your disc is a Blu-ray 3D disc, and
• you have 3D glasses that are
compatible with your 3D TV.
or the 'Fault' could be that the 3D is turned off
From Page 18 of the Manual
Play 3D discs in 2D
1 Press ( Home ).
2 Select [Setup] > [Video] > [Blu-ray 3D
video] > [Off] .
3 Press OK .
4 Play your Blu-ray 3D disc.
» The 3D video is displayed in 2D.
If it is selected as Off then obviously turn in On.
Please leave feedback
Cheers
Andy
4/26/2011 12:04:16 PM • Philips... • Answered on Apr 26, 2011
I have the phillips system.
I don't recommend doing things without a manual when one is available...
http://www.p4c.philips.com/files/h/hts5580w_f7/hts5580w_f7_dfu_aen.pdf
Think about where you TV audio originates. Unless you have an antenna on your TV, everything IT hears comes from an external audio device like a cable/sat box which almost certainly has a digital audio output and/or HDMI.
I would recommend you carefully utilize your limited connections this way:
Using Page 10 as a guide.
IF your TV has 2 HDMI's or one HDMI AND one Component input:
Cable box (Component Out and Analog Stereo RCA) or HDMI Out to corresponding TV In's if available.
Cable Box coaxial audio to the HTS (3). This way the best broadcast TV multichannel audio goes to the best electronics and speakers.
HTS HDMI Out (9) to TV Component In (if available), otherwise use Component Out (7). I recommend saving the highest quality video delivery path for your native BD because broadcast Hi-Def video is always bandwidth compromised while BD is the best video available today.
Composite Video Out (6) to Composite Video In on TV for HTS management functions.
You still have both Aux In (4) pairs).
1/25/2011 11:55:42 PM • Philips... • Answered on Jan 25, 2011
Hi...I have a Philips HTS 9520, It is stack on (Starting) on the display when i turn it on. However, I am able to select the source, but nothing plays, not even Radio. Kindly assist.
The system must run through its routine before it can start up. If a mechanism is jammed or a switch is not contacting, it won't complete its routine and therefore will not start up.
4/8/2024 5:16:27 PM • Philips Audio... • Answered on Apr 08, 2024
Philips FR-968 Stereo Receiver. How do I fix my Philips radio receiver that shows standby with no sounds or display?
Question edited for clarity. It you have standby, that shows you have power. The only things you can try is a Power Reset, disconnect from the mains, for 10 minutes. Press and hold the power button for 60 seconds and then plug back in. If you are using a remote, check the batteries in the remote. You can also do the check to make sure the remote is putting out a signal. Aim the remote at the front facing selfie of a smartphone. You should see a flash. No one else has reported your issue. https://www.google.com/search?q=Philips+fr-968+radio+receiver+no+sound+or+display ..
2/28/2024 7:16:28 AM • Philips Audio... • Answered on Feb 28, 2024
Need Circuit diagram or service menual for Philips 430/00 2.1 speakers
There doesn't seem to be one for this chinesium speaker.Probably a throw away item and not serviceable.
12/17/2023 11:19:48 AM • Philips Audio... • Answered on Dec 17, 2023
I have a Philips Kitchen
The skipping problem you are experiencing may be related to the shaft that the laser assy rides on. It may need a little greasing with silicon grease, just a litte bit. Or it could be the spindle motor is wobbling as it turns. If you are a little tech savy, then you can order a new CD drive assy through Ebay and swap it out when it arrives. If you get this far you need to know how to remove the solder short on the new assy otherwise the new drive will not work.
11/30/2023 10:20:16 PM • Philips Audio... • Answered on Nov 30, 2023
Does aj300d/05 have a fuse
The Philips iPod dock model "AJ300D/05" is not responding when plugged in. To troubleshoot:
  1. Check the power source and ensure proper connection.
  2. If applicable, look for any blown fuses as a potential issue.
  3. Verify the dock connector for a secure connection with the device.
  4. Confirm device compatibility and consider using adapters if needed.
  5. Check the remote control and its batteries.
  6. Look for a reset function if available.
  7. Update any associated software.
  8. Inspect for physical damage.
If none of these steps resolve the issue, reach out to Philips customer support or a professional technician for further assistance or potential repair.
8/9/2023 9:36:06 AM • Philips Audio... • Answered on Aug 09, 2023
Why doesn't my Philips CDR820 copy a disc when I press "copy cd" then the "yes" button?
If your Philips CDR820 is not copying a disc when you press the "copy cd" button and then the "yes" button, there could be several reasons why this is happening. Here are some possible solutions you can try:
  1. Check the disc: Make sure the disc you are trying to copy is not scratched, dirty, or damaged. If it is, try using a different disc.
  2. Check the blank disc: Make sure the blank disc you are using is compatible with your Philips CDR820. Check the user manual for compatible disc formats.
  3. Clean the laser lens: If the laser lens is dirty, it may not be able to read the disc properly. Use a cleaning disc to clean the lens.
  4. Update the firmware: Check if there is an available firmware update for your Philips CDR820. If there is, download and install it to see if it fixes the issue.
  5. Reset the device: Try resetting the device by unplugging it from the power source for a few minutes, then plugging it back in and trying to copy a disc again.
If none of these solutions work, it may be a hardware issue that requires professional repair. In that case, you may need to contact Philips customer support or a qualified technician for assistance.
2/25/2023 6:09:44 PM • Philips Audio... • Answered on Feb 25, 2023
Why is my Philips HTS6515/98 power button constantly illuminated red and will not power on?? ?
It could be due to a blown fuse and the fuse that has blown needs to be replaced.Or it could of had stopped working.
2/6/2023 8:09:36 AM • Philips Audio... • Answered on Feb 06, 2023
2answers
Philips GoGEAR MP3 player SA1942 bricked after repair got interrupted!
Contact Philips direct. They probably have drivers and a Firmware / Software Bin File. https://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=gr&ctn=SA1942/02 ..
9/25/2022 7:38:44 AM • Philips Audio... • Answered on Sep 25, 2022
2answers
Old Philips Record player start lever stuck
possible bad drive motor
3/22/2022 6:45:36 AM • Philips Audio... • Answered on Mar 22, 2022
3answers
I need circuit diagram of philips radio transistor
I need a circuit diagram for Philips Radio Model B4CA49T 1965 model can anyone suggest me where can I get it
1/16/2022 12:47:06 PM • Philips Audio... • Answered on Jan 16, 2022
2answers
I need code for Philips 22DC481/62
Ask Philips: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ca&userLanguage=en
1/11/2022 4:08:52 PM • Philips Audio... • Answered on Jan 11, 2022
My philips lx3600d was water surged now it does not have volume
Yes it can. contact Philips Support for their local service centre. https://www.philips.com.ph/c-p/LX3600D_69/- ..
12/27/2021 11:52:35 PM • Philips Audio... • Answered on Dec 27, 2021
Philips HTS5580W/F7 Theater System Logo
13 questions posted
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Audio Players & Recorders
Most Popular Question
philips hts3541 need make region free
  • Audio Players & Recorders
