20 Most Recent Sharp 65DR650 65" Rear Projection Television Questions & Answers
Model number 65DR650 part number
You can buy the color wheel from [email protected].
11/14/2013 3:01:21 PM • Sharp 65DR650... • Answered on Nov 14, 2013
Distorted picture sharp 65dr650
YOU rebuilt the engine? Everything in there is precision aligned etc and done in a space age factory---I hate to say it but everyone I HAVE SEEN ATTEMPT IT was involved in a mess.Good luck and hope you reach a good ending with the set.
6/14/2012 9:49:40 PM • Sharp 65DR650... • Answered on Jun 14, 2012
Color is off a bit. faces glow. eventually whole
I presume the model number listed with the question is correct.Usually a color wheel has some sort of noise associated with a failure or fault.I have seen the wheel for this model on EBAY at over $260 and most of the Sharps sell it only with a replacement optical engine.The color wheel faces the lamp and the pie segments spread and direct the light into the engine, if you heard any kind of fan like or high pitched sound the wheel may be your problem. Wheel is moving at about 12,000 rpm.Usually a problem in the digital processing area will not shut the picture/set off.I am not sure if it is the color wheel that it is a viable repair/ cost versus replacing set with something new.Let me know if any unusual sounds from wheel etc during or at shutdown.You may also want to Google the model number with color wheel replacement to to see if it is a do it yourself job.In either case based on cost of part it may not be a good idea to fix it.Let me know any information or concerns you have as I am here to help you.SD TECH Steve
9/28/2011 12:43:41 AM • Sharp 65DR650... • Answered on Sep 28, 2011
0answers
2answers
My Sharp 65DR650 went out today, the screen got
That humming noise was your color wheel going bad. It is part of the optical engine. I am not sure if you can replace it separately. In any case this is complicated and expensive repair.
7/11/2011 5:42:19 PM • Sharp 65DR650... • Answered on Jul 11, 2011
5answers
Sharp 65dr650 rear projection tv makes loud nois while its on
Looks like we all got screwed with this TV. Mine just started after 2 years and now it's getting louder. I think I rather call my lawyer than Tech. This product is NOT build properly and someone should let the company know about it.
7/11/2011 5:41:11 PM • Sharp 65DR650... • Answered on Jul 11, 2011
3answers
Where can you buy color wheels for DLP tv's
Any local television repair shop, eBay etc. Best bet would be to google your part number for the best price.
7/11/2011 5:36:04 PM • Sharp 65DR650... • Answered on Jul 11, 2011
I asked an earlier question and got a reply..now
Yes that I would check also sorry for not bringing that in frount of the diagnosis.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
5/6/2011 5:42:10 PM • Sharp 65DR650... • Answered on May 06, 2011
2answers
Color
U hear grinding noises,squiling noise,before colors fades in&out,turn to Black&White picture,than died?Yes,than ur DLP tv have a colors wheel,it defective,require replacing.The colors wheel is spinning off of it motor axis.The tv tech,should be hire for changing the tv colors wheel.
5/6/2011 5:40:42 PM • Sharp 65DR650... • Answered on May 06, 2011
My schreen is saying replace
ockieandlolo,
I have a tip which should help at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv . It explains the remove and replace process and also where to get the best parts at the best price.
Thanks for using FixYa and for the great rating.
hardrocko
4/28/2011 8:36:44 PM • Sharp 65DR650... • Answered on Apr 28, 2011
MY 65DR650 REAR PROJECTION TV
If you are comfortable - you can try taking the color wheel out of the tv. Pop the motor apart and clean all the residue on the bearing/spindle. Then lubricate and put it back together. Search on google for how to do this.
There is a company that replaces the motor. Search on ebay for them.
3/8/2011 9:47:12 PM • Sharp 65DR650... • Answered on Mar 08, 2011
0answers
Manual sharp 65dr650
Hi Mary
You can find your manual by clicking HERE
Hope this help
Cheers
6/3/2010 10:33:55 PM • Sharp 65DR650... • Answered on Jun 03, 2010
Replace lamp light came on
There are at least three fans in that unit. You should clean them regularly. Also there is a color wheel in the unit and it spins very fast. When they start to go bad then you get a noise also. The bad news is that as of April of this year there was no color wheel replacement for it and the whole unit is 700 to 800 plus labor. It is probably not worth it. You can call a local repair shop and see what they say. I would say that it is the color wheel. You can open the back and see what the location of the noise is and you can clean it while you are in there. If the noise sounds more like a buzz then it could be the ballast that powers the light. I just am going to stick with the color wheel though.
11/29/2009 12:18:38 AM • Sharp 65DR650... • Answered on Nov 29, 2009
2answers
I put a new bulb in.I had turned power off like
would it power up before? if so make sure your bulb is seated properly if it did'nt then your ballst is most likely your problem you will need a tech to help you out
11/25/2009 1:06:16 AM • Sharp 65DR650... • Answered on Nov 25, 2009
Hazy picture
hazy picture
10/7/2009 7:32:49 PM • Sharp 65DR650... • Answered on Oct 07, 2009
My tv will not power up. The light comes on and then goes off.
What is Wrong with TV? Have you replaced Lamp? If so and still no picture then it can be Ballast Board it connects to Lamp Box , Ballast is what turns Lamp on Call Encompass 1-800-638-3328 or Mats 1-800-628-1118 and you can also look up Parts on E-Bay!
9/29/2009 9:47:32 AM • Sharp 65DR650... • Answered on Sep 29, 2009
Sharp 65DR650 65" Rear Projection Television Logo
Popular Tags
45 questions posted
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Televison & Video
Most Popular Question
  • Televison & Video
