20 Most Recent
DSC EV-DW4975 - Vanishing Wireless Door Window Sensor Questions & Answers
DSC Power 832 blank keypad and cant shut off siren?
If the keypad on your DSC Power 832 goes blank when the alarm is tripped, there could be a few reasons for this issue. Here are some troubleshooting steps that you can try:
- Check the power supply: Make sure that the power supply to the alarm system is working correctly. Check the power connections, and ensure that the battery is charged. A weak battery or poor power connections can cause the keypad to go blank.
- Check the keypad connections: Check the keypad connections to ensure that they are secure and not corroded. Corroded connections can cause intermittent issues with the keypad.
- Check for damaged wiring: Check the wiring to the keypad to ensure that it is not damaged. Damaged wiring can cause the keypad to lose power intermittently.
- Test the keypad: Test the keypad to see if it is working correctly. Press each key on the keypad to ensure that it is responding. If any keys are not responding or are responding intermittently, there may be an issue with the keypad itself.
- Check for a faulty control panel: If the above steps do not resolve the issue, there may be a problem with the control panel. A faulty control panel can cause intermittent issues with the keypad.
If you're unable to troubleshoot and resolve the issue on your own, it may be best to contact a professional alarm system technician to diagnose and fix the problem.
2/28/2023 4:47:48 AM •
DSC Home...
Answered
on Feb 28, 2023
PC 1565 House alarm system trouble
Man, I believe that the best decision for you is just to connect with the specialists from the company that installed you this security system. That will be much better than to search for help here. I have a system from
https://ajax.systems// and when I have some troubles with this I always can connect with the specialists that fix any trouble during a day. That is great that their service is working so fast and my house is always under the protection. I also like the quality of pictures on their cameras, that is possible to see all the details of the face, for example.
2/21/2021 8:05:25 AM •
DSC Home...
Answered
on Feb 21, 2021
What is the master code for a DSC pk5501 alarm
It depends on the alarm dealer that installed it since it was set by them when it was installed. The master code is never left something like 1234. You should call the last company to service the system. You can't typically default an alarm panel to put a code back to default.
5/2/2018 11:22:00 PM •
DSC Home...
Answered
on May 02, 2018
Pc1555rkz
Could you maybe look for a brand and model on the system? Either on the keypad or on the system box (metal panel somewhere in the house)?
Then maybe Google the brand and model, looking for a manual?
5/20/2017 2:27:30 AM •
DSC Home...
Answered
on May 20, 2017
Dcs 5501 trouble light
When checking troubles on DSC, *2 brings up the trouble codes and trouble light will flash after pressing *2
1=Service Required (press 1 to get sub codes)
1=Low Battery
2=Bell Circuit
3=System Trouble
4=System Tamper
5=Module Supervision
6=RF Jam Detected
7=PC5204 Low Battery
8=PC5204 AC Failure
2=Loss of AC Power
3=Telephone Line Fault
4=Failure to communicate
5=Sensor (or Zone) Fault --- Press 5 to identify zone/sensor
6=Sensor (or Zone) Tamper --- Press 6 to identify zone/sensor
7=Sensor (or Zone) Low Battery --- Press 7 to identify zone/sensor
8=Loss of Time & Date
4/10/2014 2:47:45 AM •
DSC Home...
Answered
on Apr 10, 2014
