20 Most Recent
Sharp 13VT-K100 13 in. Combo Questions & Answers
We recently had a flood in our home and my Sharp
If you Google the model number or look at:
http://www.audioreview.com/pscTelevisions/TV-VCR,Combo/PLS_2729_830crx.aspx
It shows on the above address having a msrp of $269.00
If this has helped you, I do this here for free so take just a minute and give me a vote here.
REGARDS, SD TECH
Jumping horizontal lines when connected to CD player
I want you to do a test first. Take you TV and connect a DVD player to it and see if this problem occurs. I bet you it wont, because the problem is not with the TV nor the CD of the karaoke machine. The problem is with the sync pulses of the signal from the karaoky, and the inability of the Tv to sync-up with those signals. What I would use is a video stabilizer between the TV and the DVD player.
If the TV still has the problem with the DVD player I would then check the TV for a vertical section problem.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
IS THIS TV ANALOG OR DIGITAL?
Hello,This set is Analog and will need a converter boxThank you,Shuttle83http://www.electron-age-technologies-llc.com
Stuck on tamper proof.....remote is lost
Greetings horsepoor2,
Yes, there are a few options for new remotes for this unit. You can find several of them at the "order parts" option found at the bottom of
www.bestbuy.com. In fact there is an option to purchase the unit that matched up directly with your television
which is RRMCG1330PESA!
I hope this helps.
Thank you,
Dorothy
Go Ahead. Use Us.
Record one channel while watchign another
Ouirkygirl, a TV\VCR combo can only watch TV on a channel & record THAT channel. If the monitor is connected directly to the VCR then u should be able to RECORD what u see. Do you have a separate channel changer [buttons that say up\down channel ?] on the face of the VCR portion? If so, then u should be able to change the channel ON the VCR, record that channel, then change the channel ON the TV, .... I don't think so,.........any thing is possable
please explain your words :: "but when I record something it jumps to tha channel evern if I am watching something else at the time."
How do I operate Sharp LCD TV remote control
First of all
1. **Power On/Off:** Use the "Power" button.
2. **Changing Channels:** Use "Channel Up" and "Channel Down."
3. **Adjusting Volume:** Use "Volume Up" and "Volume Down."
4. **Input Selection:** Use "Input" or "Source" to choose input devices.
5. **Navigating Menus:** Use navigation arrows and "Enter" or "OK."
6. **Mute Function:** Use the "Mute" button.
7. **Number Pad:** Input channel numbers or perform numeric functions.
8. **Special Functions:** Access features like "Menu," "Exit," "Subtitle," or "Info."
9. **Teletext/Closed Captioning:** Access these features if applicable.
10. **Smart TV Features:** Access smart features, apps, or online content if applicable.
11. **Batteries:** Ensure the remote has fresh batteries for responsiveness.
For model-specific details, always refer to your Sharp TV's user manual. If you provide your TV's model number, I can offer more tailored instructions.
Changing analog to digital on Sharp TV
Unfortunately, you cannot convert an analog TV to digital simply by changing settings. The transition from analog to digital involves hardware changes. If you have an older Sharp TV without a built-in digital tuner, you may need an external digital converter box or consider upgrading to a newer TV with a built-in digital tuner to receive digital broadcasts.
