20 Most Recent GE TruVision DVR 10, 4-channel, H.264, 250GB Questions & Answers
HI
JUST TRY THIS LINK
http://iefaq.info/index.php?action=artikel&cat=48&id=133&artlang=en
GE TruVision DVR... | Answered on Mar 21, 2012
Win7 has both Internet Explorer 32bit and Internet Explorer 64bit.Click on start, all programs, open Internet Explorer, NOT Internet Explorer 64bit. The shortcut on my desktop was to the 64bit option and I could not view cameras regardless of permissions etc. Once I opened 32bit version cameras work perfectly. I fought with this for weeks before realizing there are two versions of IE9. Hope this helps.
go to tools, internet options, security, custom level, look for activex settings. enable or prompt should be selected on all settings to allow the browser to accept download the activex file. I just did this a few minutes ago and it worked great.
GE TruVision DVR... | Answered on Mar 23, 2011
All wireless security motions have a 3 min delay built into them. This means that whether the alarm is set or not when the motion detector picks up motion it shuts down for 3 min and will not pick up motion. This is done to conserve battery power. So I always advise customers to arm the system and stay away from the motion for 3 min total. example: 60 sec to arm system + 2min wait time. then try to trigger motion. If this does not help and assuming batteries are good, you'll need to replace motion. Good luck. This may help https://al.ly/vR54zP
GE Home Security | Answered on Dec 15, 2019
I would start by power cycling your system. Remove the battery & power. After waiting 10 minutes or so reconnect the battery and then power. Other than that you need to be a bit more specific with your issues.
GE Home Security | Answered on May 03, 2019
Try disarming system twice to get the fire zone to reset. If that doesn't work, try to downpower the entire system, including back up battery then re-power the system with the back up battery first.
GE Home Security | Answered on Oct 24, 2018
First of all, here is the direct link to the ONLINE USER'S MANUAL for that model:
http://www.novisec.nl/cms/component/option,com_docman/task,doc_view/gid,67/
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, and then just follow the onscreen instructions to install it.
See page 17 of the ONLINE USER'S MANUAL for detailed instructions on how to reset the unit to default settings. Basically it says:
Push the MENU button, select admin and enter 3477 for the password, then press OK to confirm.
Use the arrow keys to navigate to UTILITIES, then press ENTER.
Then navigate to RESTOREPARA and press ENTER.
Then select OK to confirm and the system will automatically reboot.
Please comment back here to this page if you have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Joe.
GE Home Security | Answered on Oct 08, 2018
GE TruVision DVR 10, 4-channel, H.264, 250GB Logo
Popular Tags
22 questions posted
Top GE Home Security Experts
Sean
Bill
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
View Most Popular
GE Home Security
  • GE Home Security
Most Popular Question
using ie 9 see remotely cameras
  • Home Security
