20 Most Recent
Sharp Aquos LC-15E1U 15 in. LCD EDTV Questions & Answers
Toshiba 42 lcd
All the Toshiba's I've seen come through my door for service are 14 months and newer. He's correct. Very poor for parts availability.
Aquos turned itself off and won't turn on again
hi....Your micro chip is faulty check the voltage comming out of the
42nd leg it shuold be 13 volts dc if you are not getting that voltage
replace the microchip.and the eeprom IC....
thank u rate me!!
Black rectangle appears on screen
Check the settings for the CC (closed captioning) on your menu. Make sure it is turned off - if it is set to TEXT mode you will get a black box in the middle of the screen. Also look for a button on your remote labeled "CC"
Aquos 37" LCD
I'm having the same problem with my 32" Aquos.
Karen
Raleigh, NC
Problem with power on
No you have a power supply problem on this TV set. Pretty common for this make as the capacitors and the regulator circuit In my opinion is way under rated, as there is no head room on the power supply in cases of when the screen turns really bright, or you could have a ballist problem in your backlight circuit. All of these are non repairable by the user unless you have solid state repair experience. Good Luck
Sharp TV LC60LE745U the screen remained black and an arrow on the bottom of the TV stay blinking
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
