20 Most Recent Sharp 32C-240 32" TV Questions & Answers
my sharp tv model 21qf2-A asks for a code or password of 4 numbers that I forget. What should I do?
Sharp 32C-240... | Answered on Apr 12, 2019
Same thing happened to my Sharp 29 inch. Stopped responding to original remote the first time, but a universal worked fine. Eventually it stopped responding too all universal remotes. The remotes are good, they work with my VCR, DVD player, and Receiver. It's a nice TV, but having to get up and adjust the volume every commercial break got old a few decades ago! If anyone has any other possible solutions aside from getting the sensor replaced...would be great to hear it.
Sharp 32C-240... | Answered on Jun 20, 2018
If you forget your password, please input *2398* to enter, then change to new PASSWORD . Good luck!
Sharp 32C-240... | Answered on Dec 25, 2016
If the TV doesn't have a scart input then you must use a converter/adapter to HDMI?
Sharp 32C-240... | Answered on Aug 12, 2016
If you are certain that the batteries in the remote are OK, try 173, 095, 171, 004, 006, 012, 029, 111, 112, 113, and 122.
Sharp 32C-240... | Answered on Dec 05, 2015
removing flyback lines by adjusting the FBT "Screen" trimmer measuring 4000 to 5000 DCV from G2 at CRT socket pin. Check RGB transistors in CRT board circuit to remove green screen.
Sharp 32C-240... | Answered on Aug 15, 2014
if it sound from the start, try to replace the CRT socket with the new one the screen might not work properly..
Sharp 32C-240... | Answered on Aug 16, 2013
attatch a butane cylinder to the back of the tv... add a hose to the outlet tube of the system and a self ignitor ...
VOILA , you have a TV lighter.
Sharp 32C-240... | Answered on Mar 25, 2013
www.asm-service-manual.com/List/TV%20List%20ASM.htm
Sharp 32C-240... | Answered on Jan 07, 2013
Use the remote control instead. If you don't have 1 buy a universal remote at the local dollar store. General Electric universal remotes are the best.
Sharp 32C-240... | Answered on Dec 30, 2012
Click here to download it.
Sharp 32C-240... | Answered on Sep 01, 2012
Unplu the TV from the wall, wait for 30 sec. plug it back in.
Sharp 32C-240... | Answered on May 28, 2012
This style of failure with the CX80h6 and indeed other CX80 & SX80 series SHARP 80cm sets is usually due to problems with the PIP (picture in picture) sub-board. This small board plugs vertically into the main left hand PCB (seen from rear of set) and is sealed in tin-plate for RF shielding. I've had two CX80h6 sets recently with this exact failure and both had problems with the PIP sub-board. One needed a new regular on the board while the other had a dry joint on the connector. This sub-board is not available from SHARP anymore, but in most cases the failed component is a discrete that usually can be sourced in it's own right. So this sub-board is where I think you should start your fault finding.
Regards,
Romsey
The tv have a video board problems,that the board,where it is pluging into the CRT-(tv picture tube) that the video board it is dying require trouble shoot and repair by a tv Tech.For now a temp. repair fixed solution.Tries tv turn off and on a few times,the tv video picture should return.
Sharp 32C-240... | Answered on Aug 03, 2011
change power supply
Sharp 32C-240... | Answered on Jan 29, 2011
If you can take the board out of this TV, you will find many bad solder grounds. First places to look for, are the vertical IC and the horizontal transformer. Be sure to check the solder connections on the small board connected to the picture tube. Very common problem for any and all these tube type TVs. If the vertical IC has bad grounds it would be in your best interest to replace the capacitors near and next to this IC. In any case resolder any and all bad solder connections. Your picture will return in most cases. Thanks for asking and show a few hands of support.
Sharp 32C-240... | Answered on Jan 24, 2011
Sharp 32C-240 32" TV Logo
95 questions posted
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Televison & Video
Most Popular Question
connect using skart lead
  • Televison & Video
