20 Most Recent
Sharp 27N-S300 TV Questions & Answers
Unlock my sharp 21G-fx10 TV
Unlock all of the channels on the TV by entering the factory-reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up. If you wish to get some details,
http://electronicshelponline.blogspot.com/ Pull up older posts.
The antenna/cable connector looks broken. can this
Hello
In most models of Sharp Telivisions,antena socket is an integrated part of the tuner itself and cannot be replaced with an other one. There is only one way and is to replace the tuner itself.
If you don't mind of style, you can solder two wires, one from the center pole of the antenna socket, and other from it outer rim, and take it out and connect to an external ariel socket [can be bought from electronic sparepart shop as a seperate socket] , to whcih you can connect your ariel pin. It will look a little dull, but you can face the probelm, without replacing the tuner. When making these connections, use sigle cored shield wire. It center wire must connect to the center pole of the broken tuner socket. OK.
Coaxial hookup broke off. Can i use an s cable
If your Sharp television has RCA jacks, you may use them through your VCR. Your VCR would have to have a tuner and then you may use this as a means for getting a signal. Newer VCRs and DVD players generally do not have a tuner. Thanks for asking!
The screen is fine but suddenly changes to blue
Color filter circuit of your TV, seems to be intermittent. You can not solve this problem your self, so it is recommend to take your TV to service center.
Good Luck
Rating the solution is highly appreciated.
Cable hookup broken
Sometimes you can replace the rf connector by resoldering it with a replacement rf. You will have to remove the tuner to do this. The big question is did you crack the tuner board or the board the tuner is connected to. You will really have to examine these. In most of my cases a successful replacement rf connector will fix.
27 in sharp tv
hi there, sounds like the remote "eye" or receiver is bad, could be the processor, as i have run into this problem before.
Go off on it own
Good day.
Your uni might be having some loose contacts in it, particularly in the supply section. Have it resoldered.
chris
Sharp 27N-S300 TV problems
This could be several things, but most likely a burned loose resistor or bad solder joint.
All of which causes an inoperative power supply with the result of having a "dead" set.
It would have to be checked out to find the problem.
Stargazer
