20 Most Recent Sharp 21" Multi System Stereo TV Questions & Answers
Tda9380ps/n3/3/1664 using sharp t v circuit diagram
Pls check horzontal driver transformer
3/30/2017 2:30:00 PM • Sharp 21" Multi... • Answered on Mar 30, 2017
3answers
Tda9380ps /n3/3/1664 using in sharp tv power
tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light
4/27/2016 9:32:10 AM • Sharp 21" Multi... • Answered on Apr 27, 2016
What is the wattage of resistor 601
3/22/2016 11:19:18 AM • Sharp 21" Multi... • Answered on Mar 22, 2016
Sharp 21ne61 goes in standby in few seconds
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
6/16/2015 3:41:13 AM • Sharp 21" Multi... • Answered on Jun 16, 2015
HOW DO I USE RCA REMOTE TO PROGRAM MY SHARP TV 21V1-L MODEL
Read the directions that came with the set/remote. If unavailable go to manufacturers web site for support and download copy of manual.
3/10/2015 4:23:05 PM • Sharp 21" Multi... • Answered on Mar 10, 2015
How do i fix my crt sharp 21G2-s tv whose screen is total black when switched on?
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
2/19/2015 1:34:46 PM • Sharp 21" Multi... • Answered on Feb 19, 2015
How to change the language from chinese to english in sharp tv 21AG2-S1
try going to the store and accessing their tv and menu record the steps, positions up, down across etc then do the same at home.
12/15/2014 10:21:27 AM • Sharp 21" Multi... • Answered on Dec 15, 2014
What is the correct remote control of sharp tv 21sn5 ?
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Type in the brand name of your device in the search box, and press "Enter". Universal remote controls are available at most of the electronic spare part selling shops.
7/27/2014 1:44:57 PM • Sharp 21" Multi... • Answered on Jul 27, 2014
Volume controll does not work
when u say volume control is this via the remote? if it is the contacts on the back of the remote buttons may be dirty - some remotes come apart with some screws, however most clip together - if u can open it, clean the contacts with alcolhol cleaner - like tape head cleaner fluid same stuff
7/23/2014 7:45:50 PM • Sharp 21" Multi... • Answered on Jul 23, 2014
My tv could not pick up any signal and it is also blurry.
sure you inserted the cable, coming from your cable company, or from the antenna? did you put in any signal at any port? If so and he TV still does nothing more, contact the deal you bought it.
7/23/2014 1:11:09 PM • Sharp 21" Multi... • Answered on Jul 23, 2014
What is the problem in the sharp CRT TV that has a shut off problem?
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. http://electronicshelponline.blogspot.com/
7/19/2014 1:07:28 PM • Sharp 21" Multi... • Answered on Jul 19, 2014
Chunglap rm 139e codes
To which device do you want set-up codes? If you wish to get some details, check the sites linked here. Set-up code list, and Set-up procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name of your TV / Device, in the search box at the top right of the display window.
11/11/2013 9:05:14 AM • Sharp 21" Multi... • Answered on Nov 11, 2013
"tda9380ps /n3/3/1664 using in sharp tv power
Check the horizontal output transistor. Replace the same. Collector to base, or collector to emitter short to this transistor is a common case. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
10/23/2013 12:53:50 PM • Sharp 21" Multi... • Answered on Oct 23, 2013
Av not work
This can be require resoldering of tuner section as if on most sharp models VIDEO is non lockable, this only means that you can conveniently find VIDEO through pressing of CHANNEL KEYS on the front panel. Thanks for using Fixya.
10/15/2013 9:08:04 AM • Sharp 21" Multi... • Answered on Oct 15, 2013
2answers
I need to find out
I found this on another site - after a lot of looking..... it worked for me!!
1. Turn on the dvd player.
2. Press eject
3. Type in 0000 on remote
4. A menu called region edit should appear.
5. Press 0 again for all regions.
6. Press enter
7. It goes to another region code menu
8. Press 0 again and then enter
6. Switch off dvd player and switch back on.
9/11/2013 10:52:18 PM • Sharp 21" Multi... • Answered on Sep 11, 2013
Televison & Video Logo
70 questions posted
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Televison & Video
Most Popular Question
wattage resistor 601
  • Televison & Video
