20 Most Recent
Sanyo DWM-380 DVD Player Questions & Answers
Wont turn on
REPLACE it -- cheaper than paying a qualified technician to try to fix it.
Ihave made a DVD of a TV series and the menu for the episodes appears onscreen but I only seem to have the option of playing episode one....how would I jump to a different episode?
Back in 2012, I had what I think was the same issue, an entire series, with only the 1st "starting" title. Easiest solution is to just write down the episode starting time of each one, and just enter that time to advance to that episode, or if you don't have that option, just fast forward it to the time on your sheet of paper or whatever.
My brother found me a "TRIAL" program called "ULTRA VIDEO SPLITTER" really cool which easily does what you want to do, that is divide your 4 or 6 hour, or whatever it is, enter menu titles, the works. The one I had was "ULTRA VIDEO SPLITTER 6.3.0206" from "AONE" Software. I do not know if it is still available. If not maybe one of it's cousins is!. Good Luck! (Man I said "whatever" too much! Oh well, whatever)
Tv guardian
I have the manual for the dwm-380 sanyo dvd with tvg.
Go to setup. Then Parental controls. Then scroll down to where you can enter a 4 digit code. To unlock and reset, enter 788444. I know this is 6 digits punch in all 6 then hit enter. This will unlock it. Next, you enter in your 4 digit number. This is your personal code. This may or may not work on other models. Take care.
Needs password to change parental
If you did not set the password, then there are two factory presets that may have been used. The first is 0000... and the other is 1234... If neither of them work, then it is likely that you have set your own password previously.
I need the 3 digit setup code for a DWM-380 Sanyo
Try 147 - that is one for Sanyo DVD players.
Also try 003, 007, 010, 020, 053, 057, 082, 102, 187, 166, 187, 214, 266, 511.
Hope one of those works for you. Be aware though that depending on the remote you are using, it may or may not be programmed with the right code for this Sanyo DVD player.
Anyway I hope this helps. Thanks for using FixYa.
Reset password
most factory codes are 1234 or 0000 or 5555 and 8888 but if you have changed it i will not know it
