20 Most Recent Vivitar ViviCam 3935 Digital Camera Questions & Answers
2answers
Sd memory card for vivitar 3935
Yes, you can use a 2gb SD card with this. You can use any memory card brand, just make sure it's an SD card.
11/4/2022 6:40:18 PM • Vivitar ViviCam... • Answered on Nov 04, 2022
My vivitar experience image manager wont install
Consider NOT using the Vivitar software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
4/7/2012 6:00:05 PM • Vivitar ViviCam... • Answered on Apr 07, 2012
Blocked driver
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa.
4/7/2012 5:58:33 PM • Vivitar ViviCam... • Answered on Apr 07, 2012
I have got a new computer and even though I have
4/7/2012 5:56:54 PM • Vivitar ViviCam... • Answered on Apr 07, 2012
Need the driver for Vivitar
Consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
12/23/2010 5:21:41 PM • Vivitar ViviCam... • Answered on Dec 23, 2010
Card locked
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
9/27/2010 4:08:46 PM • Vivitar ViviCam... • Answered on Sep 27, 2010
How to upload my camera to my computer. I lost
You can download the driver for your particular Operating System from
http://diplodrivers.com/download-driver/VIVITAR/VIVICAM%203935
Also you can find your manual on the same site. Please rate this solutuion. Thanks.
3/8/2010 6:59:10 PM • Vivitar ViviCam... • Answered on Mar 08, 2010
Lost cd rom for instaling vivitar 3935 camera on
allybutchart --
I searched for a more recent OS (versus Win 98), but couldn't find one... you can try this one though and see if it works:
http://www.opendrivers.com/driver/235324/vivitar-vivicam-3935-mass-storage-device-driver-windows-98-free-download.html
Since it is just the driver, you will have full funtionality, but not the vivitar extra software that usually comes on the installation disk (as long as you have another photo-editing app, you should be fine!)
If you have any further issues, feel free to post a comment to this thread, and I will be happy to assist you further!
Hope this helps!
-- RT
PS - If useful, please don't forget to vote!
9/8/2009 6:59:44 PM • Vivitar ViviCam... • Answered on Sep 08, 2009
My camera won't turn on either....
Either the lens is out of alignment, or the CCD or worse has gone defective. Either way it sounds like it may be worth it to just purchase a new camera. You do always have the option of repair as well.
Thanks,
Lee
7/11/2009 7:43:51 PM • Vivitar ViviCam... • Answered on Jul 11, 2009
My vivitar3845 is out of focus on still pics and on video, help
i have the problem solved, the vivitar 3845 is 4 years old and has served me well. decided to get new camera, thanks anyway.
5/16/2009 7:20:35 PM • Vivitar ViviCam... • Answered on May 16, 2009
2answers
Vivitar 3935
solution----purchased a new camera 1!!!! compatible with bdy Vista!!!
4/25/2009 3:22:21 AM • Vivitar ViviCam... • Answered on Apr 25, 2009
Vista
I used the win 98 driver on cd for vista or it will not open the drive had to reboot after to see drive but it does work with vista.
4/25/2009 3:18:52 AM • Vivitar ViviCam... • Answered on Apr 25, 2009
Memory card locked
Check the side of the memory card
there is a lock on it.
Hope this helps
Regards
Richard.
4/21/2009 2:53:42 AM • Vivitar ViviCam... • Answered on Apr 21, 2009
My camera wont take pictures says card locked
There is a lock on the SD card
Check this is good.
Regards
Richard.
4/21/2009 2:52:45 AM • Vivitar ViviCam... • Answered on Apr 21, 2009
Sdhc question
no it is not, sorry.
External Memory: SD Card (up to 256MB) ( Card not included)
From your specification sheet
http://www.amazon.co.uk/Vivitar-Vivicam-3935-Digital-Optical/dp/tech-data/B0007XQFJK/ref=de_a_smtd
Hope this answers your question.
Regards
Richard.
4/21/2009 2:51:40 AM • Vivitar ViviCam... • Answered on Apr 21, 2009
Date/time stamping on the vivitar vivicam 3935
should be in the menu.
11/12/2008 9:45:07 PM • Vivitar ViviCam... • Answered on Nov 12, 2008
Cannot save images?
download manual (free register)
11/12/2008 12:14:08 PM • Vivitar ViviCam... • Answered on Nov 12, 2008
Vivitar 3945 camera
You wont quite simply get it fixed. Try the Vivitar Technical Support-tell them when purchased - Dont tell them you dropped it See what happens Otherwise New camera There are no Fix options.
4/20/2008 7:12:30 PM • Vivitar ViviCam... • Answered on Apr 20, 2008
My 3935 keeps erasing memory cards...
i know it's not solving your problem, but at least it stop from happening again... You can protect images/video clips from being accidentally erased using the protect function in the Playback menu... see also: http://www.fixya.com/BrowseManual.aspx?prdid=218406&mpgid=843814&hlt=erase
11/22/2005 12:17:08 PM • Vivitar ViviCam... • Answered on Nov 22, 2005
Vivitar ViviCam 3935 Digital Camera Logo
Popular Tags
19 questions posted
Top Vivitar Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
View Most Popular
ViviCam Vivitar
  • ViviCam Vivitar
Most Popular Question
lost cd rom instaling vivitar 3935
  • Cameras
