20 Most Recent
Vivitar ViviCam 3915 Digital Camera Questions & Answers
How to upload picture to computer
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
My camera does not work on windows 7, It's a
It doesn't matter to the camera what operating system you have on your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or
Picasa.
WANT TO TRANSFER PHOTOS FROM
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as
Picasa.
I need a customer service # for vivitar digital
You don't need the Vivitar software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as
Picasa.If you really need to contact Vivitar, start
here.
When I connect my usb cord to the computer it does
Picasa.
Need a new software dics
You don't need any software in order to use your camera.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program, such as
Picasa.
How do I get the
Gently press down on the card as if to push it further into the camera. It will then pop up slightly so you can grasp it between your fingertips and pull it out.
The connection in the port is loose or maybe
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as
Picasa.
WHEN i TRY TO DOWN
Picasa.
How do I set it for a timed picture?
Press the SET button to bring up the main menu. User cursor-left/right to select "Self Timer." Use cursor-up/down to select the desired delay and press SET.
How to view pics on
Press the MODE button twice to enter the Playback mode.Full details are in the "Photo Playback Mode" section beginning on page 29 of
the manual.
My camara dont mke sound when i make a video.
The 3915 is designed primarily as a still camera, with some video capabilities grafted on. As such it captures images not sounds. You can add a soundtrack using video editing software on a computer, but you cannot record one on this camera.
Battery life
You can use alkalines or lithiums. Lithiums cost more but will last longer. In either case I STRONGLY suggest having a spare set handy.
