20 Most Recent Vivitar ViviCam 8300s Digital Camera Questions & Answers
0answers
When i find the battery
One online source is here.
2/21/2012 9:32:19 PM • Vivitar ViviCam... • Answered on Feb 21, 2012
2answers
I need a vivitar 2.5 lcd to replace in a traveler dc-8300 8.1mp
when i take the picture it comes out white you cannot see anything.
9/20/2011 2:09:06 AM • Vivitar ViviCam... • Answered on Sep 20, 2011
For a Vivitar Camera ViviCam 8300s I need a
try bestbatt.com
8/2/2011 9:17:14 PM • Vivitar ViviCam... • Answered on Aug 02, 2011
I have a Vivitar ViviCam 8300s and when I connect
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
6/22/2011 6:18:29 PM • Vivitar ViviCam... • Answered on Jun 22, 2011
My Apple computer is not recognizing my ViviCam
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
4/6/2011 6:10:43 PM • Vivitar ViviCam... • Answered on Apr 06, 2011
The lcd picture image is ok but after you take a
The image sensor has failed, not an uncommon fault. The only fix is to replace the sensor and it's a professional job only.
Replacement costs far more than your budget priced camera is worth, so unless it's under warranty recycle it and replace it, and remember to remove the memory card and batteries if reusable. If your camera is under warranty then Vivitar won't even attempt a repair: they'll just verify the fault and replace the camera with another one (same or equivalent model).
3/4/2011 10:03:00 AM • Vivitar ViviCam... • Answered on Mar 04, 2011
There is no sound on video or audio on my vivicam8320.
The ViviCam does not record any sound.
12/15/2010 5:53:33 PM • Vivitar ViviCam... • Answered on Dec 15, 2010
Why does it tell me memory card error with a new
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
11/24/2010 4:56:23 AM • Vivitar ViviCam... • Answered on Nov 24, 2010
Hey
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
9/30/2010 9:29:41 AM • Vivitar ViviCam... • Answered on Sep 30, 2010
My Vivicam 8300s has error 2, which means the lens
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
7/7/2010 1:16:18 PM • Vivitar ViviCam... • Answered on Jul 07, 2010
I need sofwear
Hello :
The software can be found on the manufacturer website .
good luck .
please rate !
4/3/2010 3:24:05 AM • Vivitar ViviCam... • Answered on Apr 03, 2010
Cannot take pictures anymore and lost my pictures in memory card.
SD cards have a little slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
3/16/2010 8:06:52 PM • Vivitar ViviCam... • Answered on Mar 16, 2010
Card problem
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
3/9/2010 6:23:05 AM • Vivitar ViviCam... • Answered on Mar 09, 2010
My camera switches on for a second then goes dead,
Yes it can be due to old battery. Please use a very good battery and a good charger along with it. Camelion 2700mAh and its chargers are good. Camelion is one example. there are many more good batteries in market. you can try any of those.
Let me know if you need more help.
Thanks
Sweet rascal
2/24/2010 10:59:34 AM • Vivitar ViviCam... • Answered on Feb 24, 2010
I need a vivitar 2.5 lcd to replace in a traveler 8300 8.1mp
First, if you can view the images, the lcd is not broken. Second, if you get an lcd screen, do you have the technical knowledge and tools to install it?
1/9/2010 7:48:20 PM • Vivitar ViviCam... • Answered on Jan 09, 2010
When the power is off, the lens doesnt retract and
1/8/2010 9:53:33 PM • Vivitar ViviCam... • Answered on Jan 08, 2010
Just bought a 2 gig SD card and camera keeps
Have you formatted the card in the camera before trying to use it?
11/12/2009 11:36:39 PM • Vivitar ViviCam... • Answered on Nov 12, 2009
Vivicam 8300s
I've been struggling with the same problem and could not figure out what the heck was goin on. When I would connect the camera to the charger the red light (indicating charging) would come on for like maybe 10 minutes. I could take pics for like 30 minutes then the camera would lose juice. Also, the green battery icon (indicating a full charge) would only stay green for like 1 minute then it would go right to the yellow battery icon (half charge). After a couple of weeks the red light indicater would only come on for like a second. I played around with mine and realized that the battery terminals were not connecting to the power source inside the battery holder. Basically the battery wasn't snug enough inside the battery holder to connect to the power. When I pushe the battery in with my finger the red light indicater would stay on. So I took a little piece of paper (folded slightly) and wedge it in the battery holder and closed the battery holder cover. Hope this makes sense! (And helps.)
10/5/2009 7:52:29 AM • Vivitar ViviCam... • Answered on Oct 05, 2009
2answers
Vivitar Vivicam driver crashes my pc
Well...
Oh the freephone number you get for customer service..... a dead line...
I eventually found a number for customer service online and...I called them.
It turns out that Vivitar products do not support Windows Vista(at least that's what I was told by them.. . The Guy actually giggled as he said that they don't work with Vista!!!
They have no plans to upgrade this product and that I "should just buy a new camera"
I asked for the head office address and the person on the other end said there was no need to be like that... I had taken as much as I could so I said my goodbyes and hung up..
I took the camera back to the shop I purchased it and they gave me a full refund....
So to sum up... If you're going to buy a Vivitar camera, my advice is DON'T.. I eventually went for a Kodak EasyShare C613 and even with it's lower megapixel (6.2 instead of the Vivitar's 8) the picture quality is far better. The tone and lighting is so much richer. And when you regitser at Kodak.com you get a voucher for 20 free digital prints and free upgrades and software...
Sorry for being so negative about Vivitar but I can not stand bad customer service!
Hope this help ...
Best wishes
Terry.
Glasgow
10/4/2009 7:52:20 AM • Vivitar ViviCam... • Answered on Oct 04, 2009
Vivitar ViviCam 8300s Digital Camera Logo
52 questions posted
Top Vivitar Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
View Most Popular
ViviCam Vivitar
  • ViviCam Vivitar
Most Popular Question
apple computer not recognizing vivicam
  • Cameras
