20 Most Recent Vivitar ViviCam 3315 Digital Camera Questions & Answers
Show date
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
7/15/2012 5:02:03 PM • Vivitar ViviCam... • Answered on Jul 15, 2012
I want to down load the pictrures from the camera
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
7/15/2012 5:01:09 PM • Vivitar ViviCam... • Answered on Jul 15, 2012
Need software
You don't need any software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what said first, you can use any photo cataloging program such as Picasa.
7/15/2012 5:00:00 PM • Vivitar ViviCam... • Answered on Jul 15, 2012
Can't get my camera to load my pictures on to my
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
4/4/2011 5:38:18 PM • Vivitar ViviCam... • Answered on Apr 04, 2011
I need a driver for my camera
2/11/2011 8:46:14 PM • Vivitar ViviCam... • Answered on Feb 11, 2011
I have the vivitar 3315
Probably the first thing to try is formatting the card. There is a function in the camera menus to do this. If it won't format or gives an error when you try, then there may be an issue with the connectors in the card slot or the card may be incompatible.
If this is a new card, maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. It is often difficult to find out the maximum capacity a camera will use, as today's memory cards are much larger that those available when the manuals for the camera was written.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
11/9/2010 8:10:40 PM • Vivitar ViviCam... • Answered on Nov 09, 2010
I need a booklet telling me how to use it. I
You can download the instruction booklet in PDF format by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
7/5/2010 6:46:51 AM • Vivitar ViviCam... • Answered on Jul 05, 2010
2answers
Just purchased T328 vivitar camera and cannot get
The T328 does not record sound with video.
3/9/2010 10:58:47 PM • Vivitar ViviCam... • Answered on Mar 09, 2010
I am getting a
Hello there Tim,
Turn off your camera and remove the memory card. On the card, look for a small tab that can be adjusted upwards or downwards. That makes the card protected. Just adjust the tab against the original position and return back memory card on the camera. That's it!
Hope this helps.
12/13/2009 5:14:03 AM • Vivitar ViviCam... • Answered on Dec 13, 2009
Where can i find a free driver
You can download your camera driver here:
http://www.edriverdownload.com/driver/Vivitar%20/Vivitar%20Vivicam%203315%20Driver.html
12/4/2009 3:13:24 PM • Vivitar ViviCam... • Answered on Dec 04, 2009
Need to get pictures back to full size on my computer.
Go into the menu and try to find an entry referring to picture quality. Choose the highest setting.
11/18/2009 12:24:00 AM • Vivitar ViviCam... • Answered on Nov 18, 2009
I need the drivers for a Vivicam 3315 camera.
If you just need to download your pics, the easiest way is to use a card reader.
11/10/2009 8:10:01 PM • Vivitar ViviCam... • Answered on Nov 10, 2009
I cannot upload my pictures..my camera is over 5
Use a card reader to download your pics to a folder you create on your desktop.
10/28/2009 9:08:21 PM • Vivitar ViviCam... • Answered on Oct 28, 2009
I have a card in the camera and still cant take photos
u will refresh ur camera or check ur memory card or put the card properly in the slot.
9/7/2009 5:15:04 AM • Vivitar ViviCam... • Answered on Sep 07, 2009
Cant get digital camera to work with memory card
have you tried to format the card before you start off with it
7/3/2009 6:08:06 PM • Vivitar ViviCam... • Answered on Jul 03, 2009
Card error
The cards are too big - the ONLY implicite statement I've seen showed the picture capcacities with a 128MB card (Yes, One Hundred Twenty Eight MEGA Bytes) It might be able to use a 512Mb card, but I doubt it.
5/30/2009 9:33:06 PM • Vivitar ViviCam... • Answered on May 30, 2009
I need to know how to work a digital camera
Most probably find a Vivitar Vivicam 3315 manual + software here. Just send them a search request.
5/29/2009 9:23:18 AM • Vivitar ViviCam... • Answered on May 29, 2009
Vivitar ViviCam 3315 Digital Camera Logo
36 questions posted
Top Vivitar Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
View Most Popular
ViviCam Vivitar
  • ViviCam Vivitar
Most Popular Question
need software
  • Cameras
