20 Most Recent Vivitar ViviCam 3785 Digital Camera Questions & Answers
Might be that the card is too large/small for camera to recognize, or it is a newer type of memory. Look up the specs for camera and compare to stats of memory card.
Vivitar ViviCam... | Answered on Nov 13, 2017
SD cards should be available at just about any department, electronics, or office-supply store.
Vivitar ViviCam... | Answered on Jan 27, 2014
Do you really need a driver?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
You can empty the card by either down loading all the photos onto your pc/laptop and then deleting all the files on the card or reformatting the card which will delete all files and folders.
Vivitar ViviCam... | Answered on Aug 04, 2013
Press cursor-down (marked with a lightning bolt) to cycle through the different flash modes. To turn off the flash select the lightning bolt in a circle with a slash through it.
Vivitar ViviCam... | Answered on Jun 19, 2013
Press cursor-down (marked with a lightning bolt) to cycle through the various flash modes. To turn off the flash select the lightning bolt in a circle with a slash through it.
Press cursor-down (marked with a lightning bolt) to cycle through the various flash modes. To turn the flash off select the lightning bolt in a circle with a slash through it.
Vivitar ViviCam... | Answered on Mar 20, 2013
Lost the Vivatar picture manager icon? How do I get it back?
Vivitar ViviCam... | Answered on Feb 07, 2013
You may download a copy of the manual from here.
Vivitar ViviCam... | Answered on Aug 30, 2012
You don't need any software in order to use your camera.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Vivitar ViviCam... | Answered on Apr 14, 2012
Consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as PIcasa.
You don't need any software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
You don't need a driver.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Vivitar ViviCam 3785 Digital Camera Logo
Popular Tags
122 questions posted
Top Vivitar Cameras Experts
Ekse
Barbat Nae
Barbat Nae
Jeffrey Groves
Jeffrey Groves
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
View Most Popular
ViviCam Vivitar
  • ViviCam Vivitar
Most Popular Question
want download manual
  • Cameras
