20 Most Recent
Skull Candy KB Electronics Skullcandy ( SCE-NF ) Stereo Earbuds Headset Questions & Answers
SKullcandy lowrider headphones cut wire
Take it to someone familiar with electronics. SOME of the wire types are very hard to solder. These are kind of "tinsel" wires for flexibility.
They likely can be repaired and some shrinkfit tubing put over the splices.
Headset is not supporting to blackberry z10
Hi try this out....Turning on, then turning off "Hearing Aid Mode" fixed the problem. The audio switches automatically between headphones and speaker normally now.
Hearing aid mode is under "System Settings" -> "Accessibility" -> "Hearing Aid Settings
My gi skull candy was
Try pressing the brackets that hold the earpiece in place, back together. This is the best I can tell you. I don't know where the crack is located at on the headphones. If you want to go this far, you can try to glue or tape the crack in place, but this is only if you want to try this. I say, if you are still getting quality sound from the headphones, then the headphones are still doing its job,
One ear bud has no sound
The wire is most likely broken to it, this is a common problem. You can try to replace it, but might have to buy another one.
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
