20 Most Recent Polaroid PhotoMax PDC 640 Digital Camera Questions & Answers
Why will the camera power on when plugged in, but will not power on when useing batteries?, the batteries are new
Batteries are new but are you sure that they are good? Did you test them for voltage and amperage? Weak batteries will often not work in older digital cameras because they needs lots of power from good, strong battery.
8/31/2015 12:55:34 PM • Polaroid... • Answered on Aug 31, 2015
How can I use my camera with my windows xp system?
Take it easy dude all you need to do is download picasa 3 then plug in your camera in the computer (USB) tthen hit import and walla you got it. Goodluck its easy. Ozout!
7/29/2014 5:38:59 AM • Polaroid... • Answered on Jul 29, 2014
2answers
If you use a memory card then you don't need a driver. Once the card is plugged in to a card reader attached to your computer, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
7/22/2014 3:14:09 PM • Polaroid... • Answered on Jul 22, 2014
2answers
Is it possible to install only the TWAIN driver for my PDC 640 camera?
Yes, you may install the PDC 640 camera TWAIN driver only. The PDC 640 TWAIN driver can be used with most TWAIN compliant image editing software. The most current driver is available for download on our website and is compatible with Windows 95, 98, Me, 2000 and XP (there is no compatibility with Windows NT at this time).
4/15/2014 3:51:41 AM • Polaroid... • Answered on Apr 15, 2014
8answers
Is it possible to recover my pictures?
You can often successfully recover deleted files from a PC, phone or camera memory card or USB Memory stick, it just depends on what's happened since the files were deleted.When you delete files the data itself isn't deleted, just the index entry that says where the data for those files is located. The space containing the deleted files is also now marked as free space so it is available to the system for any new files to be written there instead. If and when that happens, then it becomes too late to recover your deleted files so it is very, very important to not save any new files or data to the device concerned.If the deleted files are on a memory card or USB memory stick, just don't save any new files to it. One of the easiest ways to see if you can recover deleted photos is to try some picture recovery software. Recommended asoftech photo recovery as it saved my life many times.http://www.asoftech.com/apr/
2/11/2014 1:42:02 AM • Polaroid... • Answered on Feb 11, 2014
The camera beeps when we
The images you take with your PDC 640 camera are stored on a removable 3.3V SSFDC or SmartMedia 2 MB memory card (also available in 4 MB and 8 MB). Note: You must insert the memory card before you can turn on the camera.
If camera beeps is enabled, the camera beeps if the card is not installed and displays the [ ] message on the Status panel.
To insert the memory card:
1. Make sure the lens cover is closed (the power is off).
2. Open the memory compartment on the side of the camera.
3. Insert the memory card into the slot (gold side of the card facing the front of the camera).
Make sure the card is pushed firmly into the slot. Note: The camera prompts you to format the memory card if it is not formatted. The camera displays the format menu on the LCD viewfinder. Press the button next to Format.
4. Close the memory compartment cover.
If you can, try using a different memory card. Else, your memory card contact terminals inside the camera may have become worn, causing the camera to not recognize the card once it is inserted. I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
3/13/2011 2:00:16 PM • Polaroid... • Answered on Mar 13, 2011
Looking for a memory card
Most types are available from ebay
2/14/2011 7:26:27 PM • Polaroid... • Answered on Feb 14, 2011
I am trying to reload the program. When I load
I followed the directions that were posted by someone else that had the same problem. Go to my computer. Click disk drive with CD in. Click Explore. Click setup icon and then properties, and compatibility. Run this program in compatability for example, windows 95, 98, or XP, Click apply and ok.
Worked for me.
11/5/2009 2:12:20 PM • Polaroid... • Answered on Nov 05, 2009
2answers
Load pdc 640 on windows Vista....message"not compatable with nt
this product is supported on windows 95 and windows 98. You should be able to use the camera by pluging it to the computer, then open my computer and then browse inside the camera and find your pictures.
3/16/2009 6:50:26 AM • Polaroid... • Answered on Mar 16, 2009
2answers
Can I use the PDC 640 camera with Windows XP?
Yes -- with some minor modifications, you should be able use your PDC 640 camera with a computer running Windows XP.
1/15/2009 5:46:00 PM • Polaroid... • Answered on Jan 15, 2009
HELP
Dee,
I had the same exact problem. I love my pdc and was very determined to figure it out! LOL I also have Vista and my Image maker Software for my pdc640 kept getting the "Not Compatible With NT" error. This is what I did: Put the CD in and click ok when error pops up...Open 'My Computer" and click the disk drive your PDC CD is in...Click "EXPLORE"....Click the "setup" icon and then "Properties"..then click at the top where it says "compatability"---Click the white box that says "RUN THIS PROGRAM IN COMPATABILITY MODE FOR:--then scroll and choose Windows 98....click apply and Ok....then download the same "SET UP' or auto install icon! It worked for me! Please email me at [email protected] and let me know if this helped:)
7/22/2008 9:09:55 AM • Polaroid... • Answered on Jul 22, 2008
Can I use a Polaroid digital camera as a web camera?
None of the Polaroid digital cameras listed below can be used as a "web cam." All of these models are designed for taking still images only. DMC/DMC 1e DMC2 Fun! Digital 320 Fun! 620 Fun! Flash 640 Fun! Flash 640 SE Fun! Flash 820 MP3 Digital Camera Olympus C-211Z PDC 300 PDC 640 PDC 640CF PDC 640M PDC 640 Plus PDC 700 PDC 800 PDC 1100 PDC 1300 PDC 1320 PDC 2000/3000 PDC 2300Z
12/23/2007 2:58:23 AM • Polaroid... • Answered on Dec 23, 2007
Error - Kernel32.dll
Microsoft defines Kernel32 errors as follows: "The Kernel32.dll file is a 32-bit dynamic link library file that is found in Windows 95, Windows 98, or Windows Millenium Edition (Me). The Kernel32.dll file handles memory management, input/output operations, and interrupts. When you start Windows, Kernel32.dll is loaded into a protected memory space so that other programs do not take over that memory space. On occasion, you may receive an invalid page fault (IPF) error message. This error message occurs when a program tries to access the Kernel32.dll protected memory space. Occasionally, the error message is caused by one particular program, and other times the error message is provoked by multiple files and programs." .
9/21/2005 3:39:13 PM • Polaroid... • Answered on Sep 21, 2005
I don't see anything in the color LCD.
If the color LCD is not illuminated when the camera power is turned on, check the following: * The camera may be in the wrong mode. Run this check to test the LCD: 1. Make sure the camera power is on (the lens cover should be open). 2. Press the Review button (top left) on the back of the camera. The LCD will display the last photo taken. To exit the Play mode, turn the camera power off. * The camera may be connected to a TV. Disconnect the camera from the TV and try the LCD again. * The batteries may be weak. Replace the batteries or use the AC adapter. To save battery power, use the optical viewfinder when composing photos.
9/21/2005 3:31:06 PM • Polaroid... • Answered on Sep 21, 2005
Types of batteries.
You can use AA disposable batteries (alkaline or lithium) or rechargeable (NiMH or Nicad) batteries. Lithium batteries last much longer, but are generally quite a bit more expensive than alkaline batteries. You should never mix old and new batteries or different types of batteries. If you use Nicad batteries, it is recommended that you use a Nicad conditioning charger to extend the life of the batteries. Note: If you use rechargeable batteries, you will need a battery charger. The camera's AC power supply does not recharge batteries.
9/21/2005 3:16:19 PM • Polaroid... • Answered on Sep 21, 2005
My PDC 640 digital camera's memory locks up.
The camera memory may "lock" as it reaches its limit. With the camera disconnected from the PC, and on battery power, turn off the camera by closing the lens cover. Remove and reinsert the memory card. Now turn on the camera -- it should power on properly.
9/21/2005 3:02:16 PM • Polaroid... • Answered on Sep 21, 2005
ERROR: code 402 in LED panel
Error code 402 indicates an issue with the SmartMedia card. Make sure that the memory card is properly inserted into the camera. If the card is not the one that was originally packaged with your camera, check to make sure that it meets the camera's requirements. The PDC 640 digital camera accommodates SmartMedia cards at 2 MB, 4 MB and 8 MB capacities. If the condition persists after checking the above, the SmartMedia card may be faulty or corrupted and in need of replacement.
9/21/2005 3:00:22 PM • Polaroid... • Answered on Sep 21, 2005
Polaroid PhotoMax PDC 640 Digital Camera Logo
31 questions posted
Top Polaroid Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tom Shanks
Tom Shanks
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
View Most Popular
PhotoMax Polaroid
  • PhotoMax Polaroid
Most Popular Question
possible recover pictures
  • Cameras
