20 Most Recent Philips RC2573 Remote Control Questions & Answers
4answers
32lc5dc lg tv stuck in hotel mode
it is quite possible, if you bought this set from a hotel liquidation, it might still have it's lodgenet card. If it does, then it may be stuck on the channels the hotel had lined up. If there is a lodgenet card (where the cable jack is on the back) you can remove the 2 screws and just pull the card out an inch (leaving it attached to the black cable). Once that card is out, the tv should fall back to normal use. You might need to do a facotry reset to unlock TV options at that point. Only way around this would be to remove the 2 screws holding in the lodgenet card, and pulling it out of the back of the set (Don't have to pull it out all the way, just enough to disengage the data socket. Once the card is removed, you would need an actual LG remote (not the pay per view remote) and hit menu a bunch of times until it stops flashing menu on and off. Once it stops, you type in on the keypad, "98765" "ENTER". This will take you to an installer menu. Scrolling down to the highest numer there is (Should be one backwards from the "000" you start on" there is "Factory Reset" and you use the right arrow key and set it to "1" and then press enter. The TV will flicker a couple times, and then, all inputs are active.
4/19/2018 5:47:34 PM • Philips RC2573... • Answered on Apr 19, 2018
2answers
Stuck in hotel mode 32 lg lcd
hold down MENU button for approx 5 seconds, then enter 1105 this will bring up the hidden menu then turn off the hotel mode.
Hope this Helps
Cheers
Little Dish Fitter
10/26/2013 4:04:10 PM • Philips RC2573... • Answered on Oct 26, 2013
Red TV light stays on
red light stays on and does nothing is the backlight board for philips commercial line. I have found this out by messing w/them instead of throwing them out. So now instead of ordering new TVs I just replace the board.
12/3/2012 11:17:27 PM • Philips RC2573... • Answered on Dec 03, 2012
Proggram t.v. channel for-phillips t,v-model-pl9125-c-221
resert the code and download your instru. manual and proceed according with the connection diagram appearing use the common sense, logically, and clearly. www.fitness.manualsonline.comGod bless you
7/31/2012 7:19:11 PM • Philips RC2573... • Answered on Jul 31, 2012
Where can I get a RC2573 institutional remote control
just go and buy a universal
11/12/2011 2:30:27 PM • Philips RC2573... • Answered on Nov 12, 2011
0answers
0answers
Any other remotes that can get same results as
Try website like Remotes.com to buy an exact remote as the original remote.
10/23/2010 10:53:48 PM • Philips RC2573... • Answered on Oct 23, 2010
Instruction on how to use the smart loader clon99-bk01
I have the instructions. I can fax to you if you give me a number
1/12/2010 7:36:48 PM • Philips RC2573... • Answered on Jan 12, 2010
Philips RC2573 Remote Control Logo
Popular Tags
44 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
  • Televison & Video
