20 Most Recent Philips 51PW9363 51" Rear Projection HDTV-Ready Television Questions & Answers
0answers
A little oiled spilled on the motherboard while
go to the honey boo boo channel and your tv will be better. Or just get a new tv becuase you spilled oil on yours.
9/14/2013 2:26:54 AM • Philips 51PW9363... • Answered on Sep 14, 2013
How to reset the yokes on my 51pw9363/17f
Hmm...You need to be carefull when adjusting them...if can realy throw the convergene off. To adjust get the service manual first...it has a section on the yokes...
4/19/2013 6:51:19 PM • Philips 51PW9363... • Answered on Apr 19, 2013
Chirping
Chirping sounds on that model is almost always caused by shorted converence chips. The site www.TvRepairKits.com has the parts, instructions, etc.
1/31/2013 6:10:48 AM • Philips 51PW9363... • Answered on Jan 31, 2013
0answers
I have a Philips 51PW936317F and before the
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
5/18/2011 12:23:31 AM • Philips 51PW9363... • Answered on May 18, 2011
I am wanting to know how easy it should be to
Yes - counterclock wise is down - but fon't mess with those knobs. That is not the fix. .Projection sets have two very common problems listed below. bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
4/27/2011 2:58:41 AM • Philips 51PW9363... • Answered on Apr 27, 2011
2answers
I am getting double vision in top and bottom
Your symptoms sounds like a damaged convergence IC’s.
There are two and sometimes three very large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink.
Most of the time you can just correct the convergence through the television menu. All that needs to be done is line up the blue and red to the green. If the colors do not move then there may be faulty components in the convergence circuit.
If your colors line up in the middle of the set and at the top but the picture is concave then you may have a faulty component in the pincushion circuit. When this circuit fails the picture will have an hourglass shape to it with black in the middle on the sides, or you will see square objects as hourglass shapes.
You may want to consult a Television Repair Technician, or repair this yourself. If you want to tackle this yourself, let me know, I can give you some direction for the repair
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
2/5/2011 1:47:49 AM • Philips 51PW9363... • Answered on Feb 05, 2011
Picture is cut off approximately 5%-10% on left
Check your aspect ratio,reset the settings to default on the tv and make sure that on your converter there isnt something set on it that would cause that problem,ok good luck,if all fails the you will have to consult a repair shop,you can call tech supprt on your product,i would do that before taking it to a shop or shipping back to factory
1/24/2011 8:05:16 PM • Philips 51PW9363... • Answered on Jan 24, 2011
4answers
Phillips model 51pw9363 Convergence Problem
lets see.
you have an up grade for this unit.
replace original ICs with STK 392-120
if you can soldier and clean heat sink of and replace heat sink you can replace thes parts no problem.
serch for them on line cost is from 14$ to 30 each.
hope this helps you
and please give me a godd rating for this advice.
i pay $160 a month for my info and this sigt pays nothing.
thanks.
daniel.
12/26/2010 7:02:29 PM • Philips 51PW9363... • Answered on Dec 26, 2010
Hello i have a 50
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
12/22/2010 5:11:11 AM • Philips 51PW9363... • Answered on Dec 22, 2010
Led light flashes and wont come on
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
12/14/2010 9:37:37 PM • Philips 51PW9363... • Answered on Dec 14, 2010
Picture is hazy and white screens are too bright.
frist need to know what kind theres a lumiis problem
11/11/2010 1:42:03 PM • Philips 51PW9363... • Answered on Nov 11, 2010
Bow at the top of screen . Picture/words doubled in red .
you have a conv. bad chips
11/11/2010 1:38:00 PM • Philips 51PW9363... • Answered on Nov 11, 2010
Philips 51PW9363 51" Rear Projection HDTV-Ready Television Logo
Popular Tags
80 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
am wanting know easy
  • Televison & Video
