20 Most Recent Philips 60PP9202 60" Rear Projection HDTV-Ready Television Questions & Answers
After the IC replacement, convergence adjustments should be done. If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Details of this adjustments are given.
Philips 60PP9202... | Answered on May 02, 2017
I would highly recommend you to go for selling it because as your not interested to use it as the primary TV..The replacement may or may not cost you higher than 150$ which can be decided based only on seeing the TV..But if you wish not to sell this for such a low price you can always go for replacement of screen my friend!..which can be found from http://www.olx.com/q/screen/c-366/p-4
Please post for how things turned or for further assistance too.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Philips 60PP9202... | Answered on Dec 13, 2016
see attached photo, it is a convergence problem.
If you have similar problem in customer menu is a way with the remote to adjust.
If it will not adjust there then the convergence chips are bad.
SD TECH
Philips 60PP9202... | Answered on Jun 23, 2015
TV powers on, then cuts off by itself.  I have no picture, and will not let me control the tv. with remote, or manual.
Philips 60PP9202... | Answered on Apr 20, 2015
Through the front of the TV. Remove the speaker grille (IT SNAPS OFF & ON) & there is a lamp cover with 3 screws holding it in place, near the left speaker.
That lamp part#: 915P020010 $49.00 TO $100.00
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-62525
Philips 60PP9202... | Answered on Jun 05, 2014
Some projection TVs have speaker grilles that snap off for cleaning.
Philips 60PP9202... | Answered on May 22, 2014
John,
You wrote that the power light is on. Is it blinking? A blinking light can be a service code that can be researched online and narrow down the issues.
Philips 60PP9202... | Answered on Apr 24, 2014
Have you looked at the Green Picture tube to see if there is a convergence magnet that may have come off? Not sure if this model had them but it's worth looking into.
Philips 60PP9202... | Answered on Mar 26, 2014
Its a convergence problem. The three color guns have drifted and it shows on the edges. Typical of an old projector tv
These will help
www.youtube.com/watch?v=esk4nYZKFcg how-to instructions: www.ehow.com/how_2034880_perform-convergence--tv.html
Philips 60PP9202... | Answered on Mar 08, 2014
All you need is a free HDMI port. The Chromecast comes with a USB power adapter to plug into the wall, or if you have a free USB port on your TV you can use it. It works great, but there is a bit of a learning curve to understand how to connect it. I use my Windows 8.1 tablet and my Windows 7 notebook.
Philips 60PP9202... | Answered on Jan 12, 2014
The crt fluid needs to be repalced carefully and correctly...This is why we created step byt step instructions for our kits on our website www.TvRepairKits.com . In msot cases if you cleaned up the spill before powering up the tv would be fine....but its not always easy to get all the spill off the board.....look around and see if you find any burnt parts....if so post a photo here....
Philips 60PP9202... | Answered on Apr 24, 2013
I suspect you are asking about the convergence or brightness. See below for both common problems and fixes
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on Projection TV sets and a fairly simple DIY fix.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
47a7bc4.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from TvRepairKits.com
Their kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
BEFORE
Set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
AFTER
724bcba.pngSolution #2 - CRT FLUID FIX
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Philips 60PP9202... | Answered on Apr 19, 2013
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
723 questions posted
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
remove speaker covers clean
  • Televison & Video
