20 Most Recent Philips 60PP9401 60" Rear Projection Television Questions & Answers
I own a 60PP9401 60 in. Rear projection tv. My red
This set has an advanced menu for adjusting the convergence and what may have happened is the shop adjusted it (It is done with an original Philips remote) and then not SAVED THE ADJUSTMENTS INTO THE SET'S MEMORY.
I can if you have the remote get into the menu and adjust and SAVE the adjustments. If the set is HD the convergence will have to be adjusted two times, once in regular and once in HD.
Let me know if you have questions.
SD TECH
1/14/2011 6:42:21 PM • Philips 60PP9401... • Answered on Jan 14, 2011
I have a phillips 60
Projection TV sets have two very common problems oulined below.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio/Video - TV Makes Chirping Sound
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
12/24/2010 7:16:55 PM • Philips 60PP9401... • Answered on Dec 24, 2010
I have a phillips 60 in rear projection tv model
need replace convergence ic chips to resolve this issue, parts cost about $40
12/19/2010 4:45:12 AM • Philips 60PP9401... • Answered on Dec 19, 2010
We have a Philips 60pp9401, 60' rear projection
U can't alignments this even u have the original remote.Tv have a problems known as convergence problems,it dead.Colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be changes on the tv convergence board to fix convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
12/18/2010 6:09:19 AM • Philips 60PP9401... • Answered on Dec 18, 2010
I have a 60pp9401 without
Your TV most likely has one of two possible problems.
  • Screen looks 3D
12/15/2010 7:07:03 AM • Philips 60PP9401... • Answered on Dec 15, 2010
I do not have a remote for my Philips 60PP9401.
You will need the original remote control. You can get one from www.tvrepairworld.com
10/28/2010 5:44:01 PM • Philips 60PP9401... • Answered on Oct 28, 2010
2answers
Convergence problems i already used
you need to replace both chips this set uses; either STK-392-120 OR 110.
AS YOU LOOK FROM THE BACK THEY WILL BE AND IDENTICAL METAL HEAT SINKS WITH FINS TO THE FAR LEFT--NOTE NUMBER ON THE FRONT OF THEM.
TOTAL PARTS COST WOULD BE UNDER 20 DOLLARS AND I CAN STEP YOU THROUGH IT IF YOU WANT.
IF this information told you something you did not know, rate it as very helpful as I do this here for free.
SD TECH
8/17/2010 1:10:58 AM • Philips 60PP9401... • Answered on Aug 17, 2010
Images are showing in 3D
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Using your original remote go-to the settings menu then goto the convergence section.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
7/11/2010 6:44:13 AM • Philips 60PP9401... • Answered on Jul 11, 2010
I have 2 images on screen
most likely your convergeance IC is faulty , ( green color) , i had the same problem with my blue color , you need to replace it or have someone do it for you , ~~ 20 $ per ic .
4/26/2010 4:13:06 PM • Philips 60PP9401... • Answered on Apr 26, 2010
2answers
Has yellow and blue and numbers and words are double
You probably got a convergence issue. What that is is when the RGB is out of allignment witch causes one color to show more the an other or vice versa. You going to have to have a repair guy come out and look at it.
Thanks hope this helps. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
4/23/2010 11:59:43 AM • Philips 60PP9401... • Answered on Apr 23, 2010
Looks uneven almost like 3d
The lenses might have moved out of line - with power off give a gentle tap to the side of lense suspected of this problem. (power off) then switch on if there are changes then you have found your problem.
good luck
Sher
11/7/2009 6:55:05 AM • Philips 60PP9401... • Answered on Nov 07, 2009
2answers
I have a phillips 55pp935217 and I am having
You need to replace the two STK-392-120 convergence IC's and any of the 6.8 ohm protect resistors near the 3 plugs to the left and front of them. Then adjust the set in the TECH menu.
You can buy the 2 chips for less than 15 dollars plus shipping on Ebay--see Sewsales----Suburban Electronics--they have the best price and give a 6 month warranty.
I can if you need give you specific instructions on how to get at the chips and also the entry code for the advanced convergence alignment--if the set will not adjust in some way one or both of the chips are bad--the 6.8 ohm resistors are a light color--open or bad ones will be discolored in the middle--they can all be tested like checking a fuse with any ohm multimeter.
I do this here for free so if this helps, give me a vote here. If you need detailed instructions or have questions.
[email protected]
8/25/2009 4:46:17 AM • Philips 60PP9401... • Answered on Aug 25, 2009
Convergence
This set is made by Hitachi and uses two STK392-110, Sanyo amps to control convergence. You have likely one amps that is shorted causing the problem, but it's HIGHLY recommended that you replace both amps. Also it uses 1.8 ohm 1w resistors, out in front of the amps, for the yoke return circuit and one or more of them may need to be replaced if they are beyond tolerance.
For this job you need a soldering station, VU meter with a ohms test, desoldering braid and a skill level of 8 on a scale of 1 to 10. Anything 5 or above would be a category of someone schooled in electronics.
If you need to find a tech in your area I suggest http://www.tvrepairpros.com/
Hope this helps!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
5/14/2009 1:41:48 AM • Philips 60PP9401... • Answered on May 14, 2009
Picture seems to be losing its sharpness and colors bleed
Your TV most likely has one or more possible problems.
  • Screen looks 3D
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
5/7/2009 3:45:33 AM • Philips 60PP9401... • Answered on May 07, 2009
No picture/ chirping noise
Common problem with this model. Goto www.TvRepairKits.com for a kit with instuctions.
5/7/2009 3:45:04 AM • Philips 60PP9401... • Answered on May 07, 2009
Everything is shadowed
  • Screen looks 3D
5/7/2009 3:44:14 AM • Philips 60PP9401... • Answered on May 07, 2009
Convergence / Short? 60PP9401
First thing to know = your set is Hitachi made with Philips
name on it....not a bad thing, just good to know.....
Parts to change out = STK392-110 IC's sub to upgrade
STK394-160E part # CZ 01341 , change both for reliability...
Then activate Intellisense and see if all is well........T.
3/26/2009 10:24:14 PM • Philips 60PP9401... • Answered on Mar 26, 2009
Philips 60PP9401 60" Rear Projection Television Logo
34 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
convergence problems already used
  • Televison & Video
