20 Most Recent Philips Magnavox 9P6034C 60" Rear Projection Television Questions & Answers
i also have this tv. i removed backcleaned mirrior, back of screen and lenses VERY GOOD. Then turned on tv go to convergence, sepaerate cross hairs then adjust focus on lenses. Then lenses rotate maybe about a 1/3 turn total by hand. Grab ring that houses lenses and turn until cross hairs are as clear as possible. This can be done with out help by watching inside of screen. red and green are adjustable, the blue is adjustablealso but i couldnt find blue cross hairs, maybe by covering red and green lenses the blue will show on screen. anyway when done and cross hairs are clear,lenses, mirror and screen are clean, you can adjust covergence and get a very clear screencleaning will also brighten pic. Pete
Philips Magnavox... | Answered on Aug 17, 2016
Unfortunately, the needle spec is tied to the catridge not the model of the turntable. Are there any numbers on the cartridge itself? Do you have a needle that is broken or is it missing completely? If you can post a picture of the needle, I should be able to match it. Post any numbers you find as well.
Thanks,
Dan
Philips Magnavox... | Answered on Oct 31, 2015
convergence is bad. It can be repaired.
Philips Magnavox... | Answered on Sep 08, 2015
Bad convergence amp ICs will have picture looking like hourglass in 2 or 3 colors. And narrow width and/or height.
Philips Magnavox... | Answered on May 09, 2014
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Philips Magnavox... | Answered on Mar 27, 2014
It's on the main circuit board attached to a large heat sink. There may be one , two or three large IC's on the heat sink. These parts are soldered on . Be careful not to get a solder bridge between adjacent pins since the spacing is close . Parts kits can be found at shopjimmy.com
Philips Magnavox... | Answered on Jan 29, 2014
POWER SUPPLY BOARD... FIND HONEST TV TECH
Philips Magnavox... | Answered on Nov 17, 2013
Was this tv made between 1995 and 1997? The problem is in the large signal board. It has the flyback on it. You will need to find a servicer.
Philips Magnavox... | Answered on Oct 19, 2013
What was the solution to the snowy picture?
Philips Magnavox... | Answered on Oct 08, 2013
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
800 questions posted
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
ptv835 phillips
  • Televison & Video
