20 Most Recent Olympus Stylus 410 / ? 410 Digital Camera Questions & Answers
Are you sure you are using it in a mode in which flash is available?
Olympus Stylus... | Answered on Aug 21, 2017
This thread might be relevant to your problem: https://www.fixya.com/problems-solutions/t114846,p220455/Olympus-Digital-Cameras.aspx Comment on what you saw in there when you opened it up, compared to the other user. Good luck
Olympus Stylus... | Answered on Sep 15, 2013
Do you mean the Windows 95 OS or Windows 7? If you have Windows 95B (with USB support), get a USB card reader. You may need to add a USB card to your computer. (Look carefully at the manufacturer's site for the drivers, fewer companies are providing drivers for the older OS versions (before XP).) Windows 95a doesn't support USB at all. You would need a new OS. This is not guaranteed to work. If you upgrade Win95a to Win98, issues may still exist with the USB card reader. Remove the card from the camera and plug into the xD slot on the card reader. If the card reader works, you can use a version of Photoshop or any image viewer since your photos are JPEGs.
If you mean Windows 7, your computer might have an memory card reader. Check for an xD card slot. Otherwise, get a card reader (USB or internal that uses a 3.5" drive bay and connects to an available USB motherboard connector if you have one). Here is a source for several USB card readers: http://www.tigerdirect.com/applications/category/category_slc.asp?MfrId=0&CatId=2833 . Remove the card from the camera and insert it into the computer's xD slot. Then use the Windows Photo Viewer or any other image viewing or editing program to look at the pictures.
Open the card as you would any flash drive or optical disc. Go to Computer (My Computer) and access the card reader "drive", open folders to find the Olympus one. Drag and drop pictures to your hard drive or double-click to launch in the program linked to the JPEG file type.
Windows 8 will behave like Windows 7 with the card reader (for most readers).
I hope this helps.
Olympus Stylus... | Answered on May 15, 2013
Press cursor-right repeatedly to cycle through the various flash modes. The one you want is the lightning bolt in a circle with a slash through it. For full details see the "Using the flash" section in the reference manual (beginning on page 72 in my copy). If you need a manual you may download a copy from here.
Olympus Stylus... | Answered on Dec 17, 2012
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Olympus Stylus... | Answered on Sep 07, 2011
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Olympus Stylus... | Answered on May 13, 2011
Download and install VLC in order to view the videos:
VLC Web Site: http://www.videolan.org/vlc/
Olympus Stylus... | Answered on Dec 28, 2010
you can download all the camera manuals from HERE
Hope this helps.
Olympus Stylus... | Answered on Oct 09, 2010
dear sir,
the problem lies with your memory card ahich is being infected by virus or corrupted.......
if your card is working fine in other cameras then this is the problem usually caused by viruswhich happens when you are receiving files from p.c or untrusted mobiles...... and sometimes it might be software failure also, which causes some of the menu not tofunction,the only solution is to flash ur phone software from the nearest olympus care.
thank you..take care
Olympus Stylus... | Answered on Oct 08, 2010
Hi Thank you for using Fixya Online Help
Are you using Windows 7 Operating system in your computer? I have the same Digital camera with you and my work around to copy pictures or move pictures from camera is thay I purchased a memory card reader and do file transfer through memory card. Because currently there is no software available for download online.
You can check this link from time to time. Please click HERE
Hope this help
Olympus Stylus... | Answered on Sep 17, 2010
I have the exact same problem :(
Olympus Stylus... | Answered on Aug 15, 2010
hi
charge completely if problem still change battery
Olympus Stylus... | Answered on Jul 25, 2010
Do you have a manual? Here is a link to the manual:
Olympus Stylus 410 Manual
You have to navigate through the menu to get to the ALL ERASE or FORMAT selection.
MODE MENU>>>CARD>>>CARD SETUP>>>ALL ERASE or FOMAT
When you turn the camera ON and press OK, you will get the "first menu". Press the right arrow to enter the Mode Menu. Use the arrow keys to navigate to the above item. Once on ALL ERASE or FORMAT, press OK.
Also, here is a quick start guide:
Olympus 410 Quick Start Guide
Scroll down to Section 5 for instructions.
You can save the manuals to your hard drive for future use once opened.
Thanks for using Fixya.
Olympus Stylus... | Answered on Jul 04, 2010
Press down-arrow repeatedly and select the timer (looks like a one-handed clock). Press the shutter button to take the picture. The control lamp lights for about ten seconds, blinks for two, then the camera takes the picture.
Refer to the section "Using the self-timer" in the Reference Manual.
Olympus Stylus... | Answered on Jun 11, 2010
You could try using a card reader instead of your camera.
Olympus Stylus... | Answered on Apr 30, 2010
I have the exact same problem. is it just something that happens with this specific camera ? can someone please help. i spent alot on this camera and now its not working. i've had it for 4 years ?
Olympus Stylus... | Answered on Jan 30, 2010
Olympus Stylus 410 / ? 410 Digital Camera Logo
58 questions posted
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Stylus Olympus
  • Stylus Olympus
Most Popular Question
turn flash off olympus stylus 410 camera
  • Cameras
