20 Most Recent Olympus Camedia C-50 Zoom Digital Camera Questions & Answers
It's not repairable unless you are competent to strip down the camera and you can get the part. There is no way of knowing if it's the inverter which supplies VERY HIGH VOLTAGE TO FLASH TUBE and beware the storage capacitor can remain charged even if the camera is off, or if it's the tube itself. The spares will cost nearly as much as a new camera. Dismantle intuitively and look for any loose cables or wires, if not an obvious loose wire then move on. Also camera is old now.
Olympus Camedia... | Answered on Aug 02, 2014
Press the flash button (located above the display, marked with a lightning bolt) repeatedly to cycle through the various flash modes. To turn off the flash, select the lightning-bolt-in-a-circle-with-a-slash-through-it symbol.
For full details, refer to the "Flash shooting" section in the Reference Manual (page 48 in my copy).
If you need the manuals, you can download them from
http://www.olympusamerica.com/files/oima_cckb/C-50Z_Reference.pdf
Olympus Camedia... | Answered on Sep 14, 2011
The flashing Orange light means the charge is flashing.
The flashing Green light means the focus and exposure are not correct.
Have you recently replaced the batteries? Or are you using rechargeable batteries? Lack of enough "Juice" could allow for the flash to not charge up (Orange) therefore not allowing the camera to get the correct exposure (Green). I would try new fresh batteries or a new battery pack. If that doesn't fix the issue it must be a bad circuitry in the body that is shorting not letting the flash charge.
Regards,
Jacob
Olympus Camedia... | Answered on Mar 05, 2011
Solution 1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken • Select On for Rotate tall. • Photo was taken with O?¬? selected for Auto image rotation. • Camera orientation was changed while shutter-release button was pressed in continuous shooting mode. • Camera was pointed up or down when photo was taken Use Nikon-approved card. • Card may be damaged. Contact retailer or Nikonauthorized service representative. • Delete unwanted ?¬ les or insert new memory car
Olympus Camedia... | Answered on Jan 26, 2011
I found one on ebay.com for under $10 at THIS LINK
But if I were you I would move on. There are much better cameras available now at very low prices.
Olympus Camedia... | Answered on Nov 22, 2010
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Olympus Camedia... | Answered on Sep 23, 2010
  1. First, make sure your camera has fresh batteries
  2. Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
  3. Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
  4. Another method is to tap the padded USB cover part on a hard surface, for example, a desk. Sounds simple, but it works.
  5. Place the camera on it's back and look at the lens from its side. It may look slightly crooked. If this is the case, power up your camera and apply pressure gently to the side of the lens to center it. It should then extend fully.
  6. Try forcing the camera lens. Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended. Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a click as it pops back into place. If the lens is stuck at an angle, put the edge of the lens not the flat front, on the edge of a table and press the lens back towards the center. It will either click back in place and work or it will break off one of the three pins that ride in the grooves of the lens barrel. Try powering the camera back on.
  7. If the lens doesn't extend at all or it extends and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a click as it pops back in place. Power the camera on.
  8. Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a click. If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
  9. If none of the methods work, you can dismantle the camera and try to clean the lens. You will need a professional to help you on this. If you have to idea or expertise to fix the unit, better to bring the camera to any Olympus service center.
Hope this initial info/idea helps.
Let me know for any clarifications.
Olympus Camedia... | Answered on Jun 23, 2010
2 thoughts. 1, with both green and orange lights flashing the manual indicates that that means that the battery is not charged. This site provided an answer to a similar question that suggested cleaning around the battery area [see Bill BS answer to Wendy]. 2, To you and Wendy, I had a similar problem and a call to Olympus suggested the likely problem was not battery related. When you open the slide, and if you press down on the cover, around where the "s" on olympus appears, that keeps the lens extended. Don't know why that is, or how to permanently fix, but it seemed to work.
Olympus Camedia... | Answered on Apr 27, 2010
It sounds like the card is damaged, it should take a lot more photos than that.
The C-50 takes an XD memory card. These are different sizes. For example a 256mb size will take hundreds of photographs.
The C-50 is quite old and there are now different types of XD cards. It might be best to get a 128mb XD card.
The Olympus website says:
Please contact Olympus authorized distributor or service center in your region for the information about
using xD-Picture Card 512MB, 1GB or 2GB
I hope this helps.
Olympus Camedia... | Answered on Mar 12, 2010
1. Go into the camera menu and find "reset"...follow the on-screen instructions. 2. Insert the card, go into the menu and find "format"...follow the on-screen instructions.
Olympus Camedia... | Answered on Feb 11, 2010
It is a common fault as the guide track is plastic.
Mine went within a year of purchase back in 2003.
Reported it to Olympus, who informed me that a worldwide warranty wasn't valid (bought in Malaysia), however I sent the damaged one and they sent me a free replacement with UK warranty!
Olympus Camedia... | Answered on Jan 22, 2010
Olympus Camedia C-50 Zoom Digital Camera Logo
74 questions posted
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Camedia Olympus
  • Camedia Olympus
Most Popular Question
orange light flashes when turn olympus c
  • Cameras
