20 Most Recent
Olympus Camedia C-3020 Zoom Digital Camera Questions & Answers
Pictures too dark - always underexposed
Hi David,Check out the manual linked
here. Scroll down the document to the bottom of page 34. Locate the section called "Exposure Compensation" and make adjustments as needed. This should solve the problem & good luck!
I put a bad card in my camera without realizing it
One solution that has worked in the past is to clean the contacts in the camera. This can be done just by working the card in and out several times. Also take out the batteries and using cleaning alcohol on the card and working in and out of , but if you do this... allow the camera and card to air dry about 1 hour before using.
When I bought the camera came with no manual and
You may download the manual for free from
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=720Consider getting a card reader instead of a cord.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa (
http://picasa.google.com ).
Is there a cord I need to get the pictures off my
http://picasa.google.com ).You may download the C-3020 manual from http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=720
For several years my C-3020
In the camera menu, there should be a setting for "review" to allow you to set the number of seconds the picture remains on the screen. Also, you can always review the pictures you've taken by pressing the review button on the camera...it's usually a button with an arrow that points to the right.
My picture card is saying
Hi.
Check AE lock custom button:
Ensure that the memory card has no protective seal or object in front of the protection area.
See here.Ensure that the files are not individually protected (Key sign in settings)
If that does not fix the problem, then the card may be defective. In that case replace the card.
Here a manual.
I have an Olympus C-3020 zoom. I am trying to buy
- Not aware of a 6v card this is old school technology and I thought they only made 3.3 and 5v cards to be comparable with PC voltage - this was the new floppy in the day.
- A notched top corner on the left side, when facing the front of the card, indicates a 5 volt card. A notched top corner on the right side, when facing the front of the card, indicates a 3.3 volt card.
3020 camera
Just hook it in and copy all pictures to a new folder on your desktop.
I lost the manuel and was looking for a site where
you can download it at any of these sites:
www.olympus.co.jp/en/support/imsg/.../download/software/
www.versiontracker.com/dyn/moreinfo/macosx/9428
download.cnet.com/Olympus-Camedia
