20 Most Recent
E-Machines M2350 Notebook Questions & Answers
How to edit my profile picture on my facebook?
Click the edit my profile picture (beside the picture)in your facebook homepage,
> Click the profile picture, after clicking, select picture or browse can be seen on the page
> Browse picture in your computer to change or edit your profile picture, then click view profile, your profile picture already have new picture
Emachines M2350 laptop- no power
It's one of two issues. 1 - power supply. 2 - the power management chip on the motherboard. Since the power supply is the lesser of the two, try a new supply first. If that doesn't do the trick then it's the pm chip and the motherboard will need to be replaced.
*NOTE* The power management chip recognizes the type of power being used and allows the computer to switch between AC and battery power, it also allows the unit to charge the battery.
Can't connect to the internet
Find the device type and manufacturer from your computer .Once you have identified the make and model number, visit the
manufacturer's web site and download the drivers using a computer that
has Internet access. Some drivers are large in size and you may need to
burn the file (typically a 'setup.exe' or .ZIP file) onto a CD-R in
order to install it on your computer.
How can I restore my web cam?
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or update driver hope this helps you
How do I get my
You will need to double click on the Synaptics Touchpad icon on the
system tray. Select Pointing Device Properties. Then you will click on Device
Settings and select Settings. Next, you will highlight Tapping and check the
Enable Tapping box in the properties window.
My mouse will not work
Use another mouse to determine whether it is the mouse or the computer that has the problem.
Acciring network address but wont conect cant get
try to disable the LAN by clicking Start > Control Panel and then click Network Connections . Then right click Local Area Network connection then click disable. Restart the pc and do the same thing except you will enable the Local Area Network. Check if you will have internet connection..
Don't know the password for
If you have another account on your laptop that has administrator rights, log in into that account and change the password for your account. If you have an administrator account (even if you don't try putting in Administrator and leave password field blank) try using that account to reset the password, otherwise try one of the following:
- see this for XP http://support.microsoft.com/kb/321305
- or this for Vista/Win7 http://windows.microsoft.com/en-us/windows-vista/What-to-do-if-you-forget-your-Windows-password
- or if anything else didn't work you can use thrid party software from Hiren's Boot CD to reset your login password http://www.hirensbootcd.org/download/Hirens.BootCD.12.0.zip
My m250 netbook won't boot
Dear Friend
Many times this error is caused when the computer is attempting to boot
from a non-bootable floppy disk or CD-ROM. First verify that no floppy
diskette or CD is in the computer, unless you are attempting to boot
from a diskette.
If not then it seems that your windows boot file got corrupted. all you
have to do is try using your notebooks recovery CD if you dont have a
recovery CD then you have to use the windows installer CD
1 Insert the Windows XP bootable CD into the computer.
2 When prompted to press any key to boot from the CD, press any key.
3 Once in the Windows XP setup menu press the "R" key to repair Windows.
4 Log into your Windows installation by pressing the "1" key and pressing enter.
5 You will then be prompted for your administrator password, enter that password.
6 Copy the below two files to the root directory of the primary hard
disk. In the below example we are copying these files from the CD-ROM
drive letter, which in this case is "e." This letter may be different on
your computer.
copy e:\i386\ntldr c:\
copy e:\i386\ntdetect.com c:\
7 Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Thanks
Gagan Gupta
Is that helpful
