20 Most Recent
Olympus Camedia C-310 Zoom Digital Camera Questions & Answers
Difficulties on finding a 32MB picture card for my
this is an old camera which uses xd picture card format. latest format in use is sd. hence, production of chips and cameras with xd stopped years ago, and a new xd may be avaialble online, but at a very stee price. Approx $25 per peice (similar sd costs $4 per piece)
How to remove stuck memory card from camera?
Try using tools like a flathead screwdriver.It'll take some grunting, and a little patience, but it should come out.
Hope this helped!
Be Sure To Rate macapplezoo 100% Or Whatever You Think I Deserve!
Can't download pictures from the camera to my
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Need software to download pictures from Olympus
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Got olympus camedia C310 and
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as the free Picasa program ( http://picasa.google.com ).
I have removed all the
Format the card in the camera if you can. If not format it FAT in windows with a card reader and then reformat in the camera.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
My olympus is not reading
Your camera uses xD cards, not SD. Now if you are using a micro-SD adapter, make certain that the cards you are using are 2GB or less standard micro-SD cards. Your camera will not work with 4GB or larger micro-SDHC cards as that format had not yet been invented when your camera came out.
Re-charge
Please elaborate your problem providing us with more details of the problem.
Thanks for using FixYa.
I can not get the video or photos from card onto
Try this: create a folder on your desktop and label it videos. Then, using the card reader, open the files on your screen and drag and drop the videos into the folder. You need a player on your computer to play the videos so you may have to experiment trying to open them with various programs. You could also download a free copy of Quicktime from apple.com It will play many different forms of videos.
Photos downloaded to computer from picture
When you removed the card from the computer, did you:
A. forget to use the "safely remove hardware" function
B. delete the pics using the computer instead of the camera
Either of these could cause your problem. If the pics are safely on your computer, I suggest you format the card in the camera.
How do I eject the
Simple press it a little and it will then eject a bit so you can grasp it for removal.
Bob
Picture error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Is not taken shot. It's saying write-protect
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it. The position nearest the contacts unlocks it. If the switch is already in the proper position, try sliding it fully the other way and then back again.
If that doesn't work, try another card.
