20 Most Recent Meade ETX-125EC (500 x 127mm) Telescope Questions & Answers
my Meade ETX-125 makes a grinding noise when I try to slew to the left and will not move. Any suggestions will be appreciated. Bill
Meade ETX-125EC... | Answered on Nov 25, 2017
You may be able to buy this from Meade?
Contact their customer service-
http://www.meade.com/support/index.html
Usually they want you to return the scope.
Meade ETX-125EC... | Answered on Jan 19, 2012
Remove the OTA from the rear cell; unscrew the focuser shaft about half way (CCW) and remove the knob or electric focuser unit; there are three very small hex cap screws which hold the OTA into the rear cell; remove these and save in a tuna can or similar, because they WILL get lost if you place on the countertop. Once done, merely grasp the blue OTA in one hand with a rubber glove for grip and the rear cell/fork arms in the other hand and pull gently apart....do NOT twist while separating! You will see where the threaded focus rod inserts into the OTA....typically binding is causing the shifting, but most of this is due to poor milling by Meade on some 125 models. You can improve these imperfect models greatly, but do not expect to eliminate all focus shift. Run the focus rod gently all the way CCW until you feel pressure...do NOT force or you will damage. Once there apply a thick grease, such as pure white Lithium (available in the tool dept. at Lowes) in a very thin layer, pushing hard into the threads...do NOT apply too much or you risk getting this stuff on the optics eventually. Once done, put the knob on the rod temporarily and run it in and out all the way slowly about 3-4 times. Once done, run it HALF-WAY between all the way and all the way out and stop. At that position, turn the OTA to about a 45-degree tilt, with corrector down and put 1-2 DROPS of 3-in-1 oil right where the threaded rod goes into the threaded rear cell of the scope and QUICKLY run the focuser CLOCKWISE to get that thin bit of oil into the rear cell threads. Once done, run the threaded rod slowly all the way CW and then CCW about 2 more times. This procedure will greatly improve the performance....NOTE: do NOT put more than 2 drops of oil on the rod!
Meade ETX-125EC... | Answered on Dec 01, 2011
Answer would be too long here. See Mike Weasner's site below. Everything you wanted to know but were afraid to ask. I am not promoting, just a member.
http://www.weasner.com/etx/menu.html
Meade ETX-125EC... | Answered on Oct 22, 2011
take it out of lock mode
Meade ETX-125EC... | Answered on Jul 09, 2011
Please read the below website. Plenty of help and links to parts
http://www.weasner.com/etx/techtips/etx_tuneup1.html
Meade ETX-125EC... | Answered on Jan 25, 2011
Contact a local Astronomy club nearby and the members will help you with the scope.
http://www.astroleague.org/societies/list/MI
Also this is the general setup for the NON- PE version of this scope.
1. Do a calibrate motors
2. Train the drives
3. Take the scope outside and level the tripod.
4. Put the scope in the HOME position (read the manual)
5. Execute a 2 star alignment and center both stars.
Meade ETX-125EC... | Answered on Dec 29, 2010
The DEC gears are slipping and not engaging. You must disassemble the fork arm to fix this-- not very easy to do.
Meade will repair this if you return the scope to them. Here is their service phone line:
Meade ETX-125EC... | Answered on Dec 21, 2010
Only Meade will have this part-- they MIGHT sell you one??? but usually they want you to return the scope to them. Talk to several people there including a supervisor.
Contact them here:
Meade ETX-125EC... | Answered on Dec 14, 2010
You can buy this device and take prime focus images using a small digital camera. Make sure the camera can take timed photos of up to 30 seconds long.
http://www.telescope.com/control/astrophotography/astrophotography-accessories/orion-steadypix-deluxe-camera-mount
Meade ETX-125EC... | Answered on Dec 10, 2010
No, you burned out some of the circuits on the internal power board. Meade can repair the scope but you must send it to them.
That's why I always use a 12 volt battery pack and NEVER use the 110volt adapter
http://www.meade.com/support/index.html Meade customer service.
Meade ETX-125EC... | Answered on Dec 08, 2010
I coudn't find a specific article addressing this problem, but I did find a procedure for checking a lot of things inside the scope. It's for an ETX90, but should be very close to your model:
http://www.weasner.com/etx/techtips/etxtu.htm
Good luck, and hope this helps.
Meade ETX-125EC... | Answered on Dec 06, 2010
From Meade--
See this web site:
Meade ETX-125EC... | Answered on Oct 13, 2010
You did tighten the AZ clutch? You did start from the HOME position? (turn the scope Counterclockwise to the hard stop)
Then you will either have to send it back to Meade for repairs, or open the bottom of the base, and look inside and see if the AZ worm gear is actually meshing with the motor. It could have come loose.
Meade customer service:
Meade ETX-125EC... | Answered on Oct 09, 2010
Do a RESET on the hand controller. Re-enter Time, Date, and SITE, and CALIBRATE motors.
Also sometimes a bad hand controller cable will cause this. You can buy another cable directly from Meade. Call them here:
Meade ETX-125EC... | Answered on Aug 23, 2010
Your problem may not be the motor?
Is this a 497 hand controller? If it is check the TELESCOPE TYPE in the controller. It should read ETX125. You cannot just switch controllers. The controller has been TRAINED for the other scope.
To switch it you must do a RESET, Calibrate motors and then train the drives. These "values" are stored inside the hand controller. If you move it to another type of Meade telescope you must RESET and do Calibrate sensors and Training again.
The dis-assembly pictures are located on the Mighty ETX web site here:
Meade ETX-125EC... | Answered on Aug 22, 2010
Many retailers sell these. The catch is to find one that will MOUNT to the ETX125. Try these two retailers:
http://www.agenaastro.com/
http://www.optcorp.com/
Call them and see what they have.
Meade ETX-125EC... | Answered on Aug 17, 2010
Meade ETX-125EC (500 x 127mm) Telescope Logo
52 questions posted
Top Meade Optics Experts
Gep Pep
Ekse
Jerry Greenberg
Jerry Greenberg
Are you a Meade Optic Expert? Answer questions, earn points and help others
View Most Popular
Meade Optics
  • Meade Optics
Most Popular Question
meade etx 125 pe telescope ra gear
  • Optics
