20 Most Recent Olympus Camedia C-300 Zoom Digital Camera Questions & Answers
Cant get the pictured to download to Windows Vista
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
4/15/2011 4:49:15 PM • Olympus Camedia... • Answered on Apr 15, 2011
Faulty memory card - card error.
hi, May be, it is possible, but take a chance, try with another memory card, i hope you will get it from your friends. check the camera with that, if camera works properly means problem in your memory card.If camera not works means,there is something wrong in card accessing circuit of camera. If so go to olympus shop. also try to format your memory card with pc and then check the camera with that. good luck
8/5/2006 3:46:58 PM • Olympus Camedia... • Answered on Aug 05, 2006
2answers
Olympus camedia c-300 zoom auto focus
hi, really surprising, how could you fix the problem, it will be fixed only by replacing the lens assy. so just go to olympus shop. good luck....
7/28/2006 7:55:15 PM • Olympus Camedia... • Answered on Jul 28, 2006
2answers
How do I transfer my pictures from my Olympus C-220 Zoom camera to my PC?
Yes, there are two ways 1. Connect the camera via USB, and look in File Explorer or 2. Take on the Media Storage Card and put it into a Card Reader attached to the computer. https://www.manualslib.com/manual/301217/Olympus-Camedia-C-2-Zoom.html?page=31#manual ..
3/27/2024 9:57:45 PM • Olympus Camedia... • Answered on Mar 27, 2024
2answers
Olympus Camedia E10 won't power on with AA NI-MH batteries but works fine with AA ALKALINE, what can I do?
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period. Always charge sets of batteries (2 or 4) together. Make sure your rechargeable batteries are all good. One defect in a set is killing for the whole set Don't use barrettes from different sets or brands together. I had one brand good NiMH batteries and a very expensive charger from the same brand. The charger destroyed all my rechargeable (more than 60 now). When I first discovered the batteries were dropping out, I stopped using the charger, but it did not prevent all batteries to die in the following months. Every time on dropped out I had to change the set. I tried using up the others by grouping the ones with the same Ri, but not longer then a few months and I had a box full to trow away. Never use a quick charger, capable of charging them within an hour or faster. Us a charger that indicates the Ri is still low enough, so you can see what batteries are bad. Check you are using a charger for NiMH batteries. I would try another set (new) because buying Alkaline is also not cheap. I used 2700 mAh and later 2600 mAh rechargeable, all dead now. since a few weeks I'm now using 2300 mHh from another brand, costing 1/5 of the "best" I had before, and they are doing great. I won't charge them with the quick charger. Never use manganese (Zinc-Carbon) batteries in electronic devices. These batteries are only to be used in flash lights.
12/7/2016 8:12:01 AM • Olympus Camedia... • Answered on Dec 07, 2016
How to use zoom on c-860L
This 14 year old camera, does not have a zoom lens. It has a 5,5 mm lens, giving it a angle of view of about a 35 mm lens of a Full frame camera. However, you should be able to zoom digital 2 times. I can't find a manual, to help you on this, but the quality will be the same as cropping into a frame on your computer. So if you do put the pictures on a computer, you also can "zoom" in to the parts you want. Be aware a 1 megapixel camera, does not offer that much of detail.
10/27/2014 11:34:04 AM • Olympus Camedia... • Answered on Oct 27, 2014
Zoom error olympus
Lens is out of possition and stuck.
7/31/2014 7:19:31 PM • Olympus Camedia... • Answered on Jul 31, 2014
Camedia e20 problems
Put memory card into camera right way around.
7/5/2014 6:38:40 PM • Olympus Camedia... • Answered on Jul 05, 2014
Camedia e20 wont record picture
Hi, any error messages?
6/20/2014 1:31:49 AM • Olympus Camedia... • Answered on Jun 20, 2014
0answers
Manual setting of focus
Like many point&shoot cameras, the SZ-12 does not have manual focus. The closest you can come is to point the camera at the object your want in focus, press the shutter release button halfway, then frame the photo the way you want it and press the shutter release button the rest of the way.
12/16/2013 4:24:41 PM • Olympus Camedia... • Answered on Dec 16, 2013
Busy signal when I try to download photos
What model Olympus camera? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (http://picasa.google.com).
11/23/2013 9:52:37 AM • Olympus Camedia... • Answered on Nov 23, 2013
Busy comes up when I try to download photos
What model Olympus camera? Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (http://picasa.google.com).
11/22/2013 11:24:51 PM • Olympus Camedia... • Answered on Nov 22, 2013
Find PHOTO on hard drive
To be sure your camera can connect to the PC. if it does, download a photo recovery software called hodo photo recovery which help me before. you can recover your photos by it.
8/7/2013 9:12:04 AM • Olympus Camedia... • Answered on Aug 07, 2013
Olympus Camedia C-300 Zoom Digital Camera Logo
7 questions posted
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Camedia Olympus
  • Camedia Olympus
Most Popular Question
olympus c 3000 zoom
  • Cameras
